ayokis Posted May 2, 2011 Author Share Posted May 2, 2011 after making the dimensions, heres the crate box of the terran marine. Still need to do some cutting and replacing the sides with Wire Mesh and Mini Fans Il try to have a cooler master laser logo placed here in the center with matching led lights. A more detailed 3D look of the crate terran marine box ( unfinished ) This weekend Il be getting some Volcanic Materials and make a base for the whole Project. The Base will be similar to one of my Mcfarlane action figure. The difference is that I will use a real Volcanic Debris / Deposits as my base. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted May 2, 2011 Share Posted May 2, 2011 I log in just for this ... say for now... Nice one Bro! Inspiring... Link to comment Share on other sites More sharing options...
sunnyXtremist Posted May 2, 2011 Share Posted May 2, 2011 I think this is the poorest setup being presented here in coolermaster competionComing from the 3rd world country, Philippines. I was once in 2009 Link to comment Share on other sites More sharing options...
ayokis Posted May 2, 2011 Author Share Posted May 2, 2011 Thank you so much sir sunnyXtremist .... appreciate it a lot. Even though my pc setup is not that expensive and doesn't have enough muscle power due to lack of funds and sponsors..... I'l still try my best and use some materials that hasn't been used in any modding competition. Volcanic materials is one of them. Again... thank you sir for looking. Link to comment Share on other sites More sharing options...
ayokis Posted May 2, 2011 Author Share Posted May 2, 2011 tomorrow il be posting 2 cooler master products that is required for this competition. it may not be that expensive but it is also the only CM product i can afford as of now. Link to comment Share on other sites More sharing options...
ayokis Posted May 5, 2011 Author Share Posted May 5, 2011 Already got 2 cooler master products just now courtesy of Sir andrew and Ms. anne. Thanks for being so generous mam and sir. The Cooler master GX 500W PSU and Cpu Cooler Vortex plus. This is a little bit heavy, so a little modding will do, starting with the replacement of housing to acrylic. il try to replace this fan to a led fan instead. the CPU cooler Vortex plus.... Not that expensive but serves its purpose Will replace this too with Led Lights fan il start working on this two products tom...... Link to comment Share on other sites More sharing options...
ayokis Posted May 9, 2011 Author Share Posted May 9, 2011 While still waiting for some products I ordered to work on the CM products, My partner and I decided to head to Pampanga where all volcanic materials can be found. Some of the pinatubo volcanic debris can be seen at the bottom of this bridge in Pampanga. no more houses in this area. all you can see are lahar and some remants of small village this is what it looks like from the bottom side of my vehicle The actual Volcanic ash / sand that we will be using for this project Getting large amount of Lahar Link to comment Share on other sites More sharing options...
ayokis Posted May 9, 2011 Author Share Posted May 9, 2011 While playing around. I decided to put side by side the actual StarCraft 2 Orginal Game. Actual picture of Terran Marine from the Game itself.... but, hmmm.... NO Terran Marine GUN? Well.... MIght as well build one big Terran Marine Gun. Hows This? Hoping to get the details of the Terran marine gun. Another eye candy Terran marine with his gun and gun shell together with the stepped on Zerg hmmmm.. where will i put this? Terran marine is getting lonely, thats why he needs a companion.... Manny Pacquio figurine! Link to comment Share on other sites More sharing options...
ayokis Posted May 9, 2011 Author Share Posted May 9, 2011 After the Clay..... The Fun Part. Casting. Link to comment Share on other sites More sharing options...
ayokis Posted May 9, 2011 Author Share Posted May 9, 2011 well start by pouring the RTV rubber molding on top of the Zerg Clay after pouring the RTV rubber molding putting up a casted chalk around the RTV molding after a couple of hours, by taking out the clay,this is what it looks like a closer look from the inside removing all excess rubber molding needs to clean it thouroughly Preparing the Secret ingredients. mixing it up with talc Mixing up with the Most important ingredient of all..... Volcanic Ash / Sand mixed it with black coloring getting ready to mix it with fibers preparing for action putting a hardener compound pouring inside the rubber mold mixing it up with fibers filling it up this looks more like a dead rat than zerg After waiting for a few Minutes..... removing the final resin cast from the rubber mold Presenting....the Resin output of zerg Before and after. The Resin and the Clay Zerg now ready for Airbrush Painting..... Link to comment Share on other sites More sharing options...
