KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 磨髮絲紋(Hairline grinding) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 å·¦å³å…©æ—ä¸‹éƒ¨é–€åŠ å›º!(Reinforcement under the department of left and right sides!) æ°´æ³µreply(Pump reply) æ°´æ³µ(Pump) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 鑽å”(Drill holes) DIY é˜²éœ‡è† (DIY Damping rubber) 朋å‹ä¸è¦çš„壞LCD MON(Friends Do not bad LCD MON) DIY LCD MON CSAE 計算尺寸,åˆ‡å‰²ææ–™!(Calculated size, cutting material!) 內部尺寸畫線!(Internal dimensions drawing a line!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ä¸éŠ¹é‹¼ç¶²(Stainless steel wire mesh) LCD MON 完æˆ!(LCD MON Complete) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 ç¶ä¿®LCD MON底æ¿(Maintenance LCD MON Motherboard ) æ›´æ›é›¶ä»¶(Replacement Parts) ç¶ä¿®æˆåŠŸ!(Maintenance success!) DIY CPU 水冷é (DIY CPU WATER BLACK) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 DIY CPU 水冷é (DIY CPU WATER BLACK) 磨髮絲紋(Hairline grinding) 剪è£ä¸éŠ¹é‹¼ç¶²!(Cut stainless steel net!) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 LED開關制(LED POWER) I/O颿¿,åŠ è£2組sataé–‹é—œ(Panel, the installation of group 2 sata switch) 140MM風扇和120MM X 2 風扇ä½(140MM fan and 120MM X 2 fan-bit) 鑽å”(Drill holes) ç©æ¢³é–‹å”(jigsaw Openings) 大部份é…ä»¶(Most parts) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 填原åç° (bentex autobody filler) 噴油漆 (Spray paint) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 安è£ç¯‡:(Installation articles:) 安è£è·¯è»Œ:機箱背部Iæ’電線時,åªè¦è¼•力拉出機箱! (Install tracks: back of the chassis when I plug wires, gently pull out as long as the case!) é˜²æ’žè† ç²’:減低變身時的碰撞(Collision particles:Reduce the time of the collision turned) 焊接POWER,RESET制(WELDING POWER, RESET ) LEDå’Œ SATA 開關制(LED and SATA POWER) Link to comment Share on other sites More sharing options...
KITSON CHAN Posted May 4, 2011 Author Share Posted May 4, 2011 安è£DVD SATAç†±æ’æ‹”æž¶(Install DVD SATA Hot Swap Rack) LED 燈ä½(LED lights) Link to comment Share on other sites More sharing options...
