Ban Nguyen Posted May 14, 2011 Share Posted May 14, 2011 First.sorry for my bad English so not much explaination From Vietnam my project name is RAMPAGE base name of ASUS RAMPAGE III Xtreme. Sketchup idea design. Most material i used acrylic to easy laser cut. Mainboard tray. Making Triangle Reservoirs Link to comment Share on other sites More sharing options...
Ban Nguyen Posted May 14, 2011 Author Share Posted May 14, 2011 In and Out for reversvoir. I custom some parts on ASUS RAMPAGE III Xtreme include Chipset and Mosfet I used the top of Coolant Flow Meter to make the top of my chipset block. LINKhttp://www.koolance.com/water-cooling/product_info.php?product_id=288 Custom chipset base. Make base to hold VGA card with aluminium Chose ASUS HD 6970 PCI-E Riser Plex Remove HS Koolance 6970 Block temporary build. Make VGA cover Link to comment Share on other sites More sharing options...
Ban Nguyen Posted May 15, 2011 Author Share Posted May 15, 2011 Preparing to set up Rampage and install parts. Painting Rebuild chipset block. Custom some srews. Top of Rever Base of case painted Link to comment Share on other sites More sharing options...
PaPang Posted May 20, 2011 Share Posted May 20, 2011 Wow, excellent and creative acrylic work! But, is it finished? A lot of vital components are missing, that is for a fully functional computer. Here at CM it is a sort of an unwritten understanding as it is in a lot of forums. No shame in not finishing but if you want to make a name for yourself, you do have to atleast finish. The rest is appreciation of the panel of judges and somewhat your popular support, and of course if you should win one of the 3 places, no need to further explain. English helps a lot because a lot of us are sort of "chatty" and your feedback is a sign of camaraderie. Where are you from? No shame either, you might set the example for others there and lead a school of modding to glory. Cheers and Saludos Link to comment Share on other sites More sharing options...
MonsterMawd Posted May 20, 2011 Share Posted May 20, 2011 Saweet design, very original! Link to comment Share on other sites More sharing options...
