Corsaronero333 Posted August 15, 2012 Share Posted August 15, 2012 Hello I introduce myself my name is Ermanno I love modding and now I want to present my work. I hope you like it, the path will be 'long. The project is in most 'parts, the first will be' all the components in brushed stainless steel I apologize for my English but I'm 'using google translator Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 After 2 weeks the pieces arrive ...... Still from the film wrapped and ready to be reshaped as needed. Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 Eheheheheh is beautiful ...... but the change is coming. First of all I have to remove the upper part of the support, because hides too much HD or SSD, so doing I take this opportunity to drill further supports aloggiare SSDs also in more 'I have to drill and countersink the bottom then I'll need' for anchor at the base, after threading from M3 Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 And here is the base perforated with 2.5 mm drill bit and threaded M3, the glazing was buffing because the original in my opinion was a little 'too, I made ??more so by the' soft, you'll notice the rear two special screws that are intended to guide the upper support Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 From here begins the frenzy to see how it comes out, and basically makes' her dirty figure, everything fits perfectly Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 As last working, I just have to remove all sharp edges with a file, mount the rubber Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 15, 2012 Author Share Posted August 15, 2012 And after many adventures here we are with the supports of the SSD mounted Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 16, 2012 Author Share Posted August 16, 2012 And here is the second processing, brushed stainless steel. This keeps the same basic design as that of HD but change its width, the top will be slightly extended to cover the whole frame of a possible DVD. Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
Corsaronero333 Posted August 16, 2012 Author Share Posted August 16, 2012 Before starting work, I have to drill through with a peak of 2.75 and then threading from M3 and countersink the screws where they will go to find accommodations. Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Link to comment Share on other sites More sharing options...
