clarkie Posted August 23, 2012 Share Posted August 23, 2012 Will post updates when the materials arrive. Link to comment Share on other sites More sharing options...
frozensnail Posted August 23, 2012 Share Posted August 23, 2012 Good to see the scratch builds coming into the Case Mod Comp, be watching this one, any overall dimensions of the sketch & how big its going to be in the flesh, any hardware news & air or water cooling going into the build? Link to comment Share on other sites More sharing options...
wwwicked Posted August 24, 2012 Share Posted August 24, 2012 Seems to be a nice project, really looking forwward for updates. Link to comment Share on other sites More sharing options...
clarkie Posted August 25, 2012 Author Share Posted August 25, 2012 @frozensnail I'm thinking of water cooling for the build but I want it all cooler master in cooling system so I will be using using a cm v8. The size?? Hmmm. We'll see on how large will it be when I finished the replica. Link to comment Share on other sites More sharing options...
clarkie Posted August 25, 2012 Author Share Posted August 25, 2012 side panel details frame details front panel details all dimensions are in Centimeters (CM) Link to comment Share on other sites More sharing options...
tnecniv102 Posted August 29, 2012 Share Posted August 29, 2012 @clarkie nice mod. i think i't will look nicer/ cleaner if all the cables at are the back. Link to comment Share on other sites More sharing options...
TERW_DAN Posted August 30, 2012 Share Posted August 30, 2012 What are you planning to do with all the cables, run them through your mod, or make de i/o panel on the side of the mod? Link to comment Share on other sites More sharing options...
frozensnail Posted August 30, 2012 Share Posted August 30, 2012 Like the concept using the V8 cooler, will / does everything fit ok & look in proportion to the jeep? Can't wait to see more on how you go around building it all. Link to comment Share on other sites More sharing options...
