zagor Posted October 2, 2013 Share Posted October 2, 2013 Still doing stretch's to decide which build i plan on using, but leaning towards a mythical creature of some sort Link to comment Share on other sites More sharing options...
zagor Posted October 3, 2013 Author Share Posted October 3, 2013 My build is going to be a dragon skull these are rough sketches of a skull. it will be changed a bit along the process. the right eye will be a huge crack in the skull so you can see inside the skull into the pc hardware. I am planning on putting fans into the nose blowing out. and working on a project to create smoke coming from the nose. the left eye will be the power switch. and under the eye will be were the cd drive will be placed well hidden. Even though there wil be lots of hand room in the back to place hardware. I am planning on making a sliding shelf were the mother board attaches to. Material to make the case is still being decided while I make a mold of how big I want the skull to end up being Link to comment Share on other sites More sharing options...
zagor Posted October 3, 2013 Author Share Posted October 3, 2013 . Link to comment Share on other sites More sharing options...
zagor Posted October 3, 2013 Author Share Posted October 3, 2013 The goal is try and make it look as possible as real bone as I can Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 started with the sulpture Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 started with mold first Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 the olther side for the open case part Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 now starting to add detail Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 other side Link to comment Share on other sites More sharing options...
zagor Posted October 22, 2013 Author Share Posted October 22, 2013 I have Change my look for the case a tiny bit. inside the head going to add some pusling vein lights. and have figured out how to achieve smoke affect more pictures to come Link to comment Share on other sites More sharing options...
