ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello everyone, an update for today, the side doors. After losing a week in idleness, also because I was waiting of the glass to be able to continue the work. Another issue is the fact that I have delayed ordering the connectors, as that only arrived in March I've dropped out of order, and so my work grows more than expected. The two doors already with glasses on. After spending more than 40 hours on the doors since the last post, in order to reduce working hours I'm going to need a machine for cutting/drilling/router type linear machining, apart from the fact that I am satisfied with the work and labor, I also need idle time to muster weird stuff. That's all for now. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello modders, it's been a while. Although the competition is finished I hope to continue to post on this forum until I have the project ready. For today I bring the underside that will accommodate deposits and the hinge system. The painting has given me a lot of work because I haven't been able to get the right color and it's one of the things that I do not understand almost nothing. Despite the problems that have arisen the good news are the dimensions of the case, which will replace the 331, fits under the desk. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello everyone, today I bring to you another update, this time the doors are already in the right place and functioning properly, the solution was to pull the shaft to the top, and to complicate, the situation got better. The lower area of the box looked like a ferry boat was crafted in front for the moment, and getting the box mounted until it gets well, also some accidents of course the ink level. Until next update. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello modders, for today I bring another update, the front renewed with the DVD drive in the top position in order to avoid conflicts with the door. The last outside part was the easiest to carry out and the next step will be to dismantle everything, sanding and painting. Inside the box left to do the power supply and access to deposits caps. By now are these photos, I'm sorry to have taken so long to get here. See you later. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello modders, for today I bring a month update of hobby. The pieces finally met the White right (this glossy white), The feet are covered in gold leaf, as they have the responsibility to stand with everything on top. Deposits are actually two fire extinguishers, one of two kg of CO2 and one of six pounds of powder, both lost contents and received internal treatment anti oxygen (anti-corrosion zinc spray), the visible tubes are for filling of liquid refrigerant. The blocks and radiator EKWB are well inside the box, because this is being done by measure. In front, the acrylic jars filled with light and, with the right touch until they are able to change color. Jokes apart of that I got rid of, just missing the sleeving, covers for the source and disks with the brand name and, more important, my version of the connectors. Take care. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Greetings, Here comes a small update, the scheme of fittings and a sample of it. In the middle is virtue. Until then, take care. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Greetings modders, For today I bring the fittings almost done, it’s missing the video card, and the pump cover. More to come soon, until then. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Greetings, here's an update. This week I haven't had much time. Just for complete the pump cover. Also made the psu cover with the holes to pass the wires, the original fan is green and will be replaced by one white, also with 140 mm. Tweaked on the back of the motherboard, and actually went well, I used the M4 holes and made a box for the hard disk, shown here with an old disk. In the section of the wires already appears a acrylic part for the wires of the motherboard and another mounted on the radiator for the fans and fans leds. Of rest are photographs of details. Until next time, take care. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Greetings, here follows a small update for this day. Made a change in my Artic Extreme II gpu cooler, switch the three 92mm fans for two 120mm Sickleflow, also put a home made copper heatsink to vrm and ram. This all together with a huge four slot alu case. Bleh To much taller. Gpu enclosure, take two. That's all for now, take care. Link to comment Share on other sites More sharing options...
ST.o.CH Posted July 24, 2014 Author Share Posted July 24, 2014 Hello modders, this is the last update. I want to thank Peter Sanj and the EKWB for being the first to believe in my project and help me to make it possible. Here are the photos. Working with zero leaks. Lights on. Spectrum. The G3n3s1s and FACTOR_I together, different styles and attributes. And also thanks to the community for the feedback. Link to comment Share on other sites More sharing options...
