Jump to content
Cooler Master HAF Stacker MbK
kier
Hi my fellow modders,
Think you have heard of this new case(s) from Cooler Master: The HAF Stacker
This combines the HAF and the Stacker series and has a nice and new concept: modular cases
The case is designed so that can be used to create different configurations. The various housings combined with each other
This time I will use all 3 parts to build a case that is somewhat larger than normal.
I will also make use of the fact that there is a great competition going on. Presented by ..... Cooler Master.
Because they have again the confidence in me to work with this brand new case, I will try to do a Cooler Master casemod competition theme. This will include logos, shapes, little advertising and some updates on this event.
I will NOT participate this year because of the sponsored case;)
So if you like to win beautiful prizes...Come on and participate!!!
How it all began:
Sometimes I have a lot of respect for the postal guys. The 3 packages
Larger then my son
Unboxing.
These are the different modular cases:
Once stacked ... BIG :)
First some detail shots.
The 925:
Inside:
More parts soon!!!
Link to comment
  • 2 weeks later...
Update!!!
First some pictures from the two parts I have received also...
The 915F where the PSU is mounted at the front
The 915R is for the PSU at the back
And some pictures outside
Time to stack all
915R placed beneath
915F on top
Pretty BIG!!!
Time for some modding I think.
This time a little different kind of modding. I rotated the case, so it becoming a kind of ghetto blaster.
I have slightly modified the connection strips so it become all the same on both sides. and removed the unnecessary stuff... maybe placed back later.
Looks nice all ready
Placed the original modo tray back under a small angle
Did some cutouts on both sides
Removed some steel from the top
And placed the tray again
There will be other hardware but this is for measurments.
Placed some acrylic underneath the motherboard tray for mounting some great products....But more on this later.
Thanks for your attention ;)
Link to comment
  • 4 weeks later...
Update!!!
All the beautiful products have come in the past few weeks for this build. Therefore a major update with everything. There will be 2 updates this weekend, because it's a lot :)
First, there was a nice package from Cooler Master
Including pretty amazing fans: The newJetFlow's 120
Because I'm still not sure which color I'm going to use, I have requested three available colors
JetFlow 120 white
Some specs from these great fans:
  • [*:1kcy6yof]LED Color: Dark (No LED) / Red / Blue / White
    [*:1kcy6yof]Dimensions: 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
    [*:1kcy6yof]Fan Speed: 800-2000 RPM (PWM) ± 10%; w/ silent adapter: 1600/1200 RPM (fixed)
    [*:1kcy6yof]Air Flow: 95 CFM ± 10%
    [*:1kcy6yof]Air Pressure: 2.72 mmH2O ± 10%
    [*:1kcy6yof]Life Expectancy 160,000 hrs
    [*:1kcy6yof]Noise Level: 19 dBA (1200 RPM with included silent mode adapter)
    [*:1kcy6yof]28 dBA (1600 RPM with included silent mode adapter)
    [*:1kcy6yof]12-36 dBA (PWM)
    [*:1kcy6yof]Bearing Type POM Bearing - CM 4th Gen. bearing (*POM: Polyoxymethelene)
    [*:1kcy6yof]Connector: 4-Pin (PWM)
    [*:1kcy6yof]Voltage: 12 VDC
    [*:1kcy6yof]Current: 0.4A
    [*:1kcy6yof]Power Consumption: 4.8W
Shock-absorbing feet
Also in red
And without LED, all black
Comes with 2 adapters: 1 for 1600 RPM (28 dBA) and 1 for 1200 RPM (19 dBA)
Power on
More about the Cooler Master box later ;)
Also EKWB is helping me with this build, so also a nice EKWB box:
With lots of lovely products
First, I have requested two beautiful radiators : De EK-CoolStream RAD XT (480)
Looks very good with the new Cooler Master JetFlow's
This set will be placed on both sides of the HAF Stacker, like this:
For this my good friend Pascal and I made 2 beautiful covers:
With nice looking bevel edges
Thanks Pascal van Veen, another piece of art man.
For this cover I first pasted a layer of white vinyl and then black.
EKWB radiator behind it with the JetFlow's
Also, I requested two beautiful reservoirs. The EK-RES X3 400
With mounting material
And two extra multiport tops to try some things.
Which will be placed like this
Before the update is getting too big, I'll be posting the rest tomorrow. But one more thing ... I received a very nice tool from Mnpctech For my favorite tubing
De Reamer
A very nice tool to use internally and externally too deburr and ream edges
More tomorrow!!!!!
Link to comment
Update!!!
We go on with the EKWB box
For this build I will use Acetal blocks. First the CPU block.... A EK-Supremacy
And two beautiful RAM blocks, the EK-RAM Monarch X2
Will be placed like this
As you can see I'm going to use the 90 ° and 45 ° black EK-CSQ adapters this time.
The RAM blocks with adapters:
The EK-CSQ 90° adapters:
And the EK-CSQ 45° adapters:
Also in this build I will use the EK-HD Adapter 10/12mm for the Acrylic tubes
Female version: EK-HD Adapter Female 10/12mm
Out of sight, I'll use flex tube with the EK-CSQ Fittingen
Which then results in a picture like this:
And yes ... a new motherboard. The ASUS Maximus Formula VI
Thank you ASUS for providing this beautiful motherboard
The motherboard :)
With backplate
Installed
As for the GPUs, I'm going to use 2x ASUS GTX780 DCII
On this two great waterblocks, the EK-FC780 GTX DCII
Installed onto the GPUs
With backplate
Time to install both sides
Unfortunately don't have enough matte black vinyl for the right cover, so can't finish this one yet.
I did make a cover for reservoirs with black gloss vinyl.
Further more made covers for the Mobo tray, sides and the top.
Beneath the angled tray of the mobo I have a nice space for SSDs. So I cut a plate, made it black again and mounted the SSDs
Just don't know yet whether I will place it in an angled or straight position.
Placed the reservoirs again.
Cut the top plate cut and made it black also
+ A cover for the mobo tray with the size of the mobo cut out
Installed it
Placed the GPUs
More next week ;)
Link to comment
Today we continue to add some more colors, and a tricky part ... Tighten the acrylic tubes.
Update!!!
Back to the sides. Regarding a wrong size radgrills from a previous build I still had some CNC milled radgrills. perfect and come in very handy.
Cant say this enough ... Never throw away stuff ;)
I placed them behind the fanholes and mounted the radiators on it.
After some thinking regarding the colors, I decided to combine these colors.
Red and white Cooler Master's JetFlo
Little bit darker
Really great fans!! But will have to dim the airflow lol, now they almost blow the sides away :)
Luckily I received last Friday the black vinyl, so the right side is also finished. Once both sides installed it looks pretty big now
And turned the fans on again... enjoying the colors
So did some thinking about the colors for the loops and going to let it flow just like the fans, outside red, inside white.
In front of the SSDs, the reservoirs... like this:
Placed the inlets horizonta and parallel to the reservoirs and just like the other tubes.
Now the challenge. The acrylic tubes that all placed horizontally will need be tighten to something to continue connecting it. So after some brainstorming, I've made a piece of aluminum ​​with holes for tyraps and tighten the 4 tubes from the RAMs. And for the two tubes of the CPU I have cut an acrylic plate and also cut two holes in it.
Placed a female EKWB HD adapter and a compression fitting.
Unfortunately out of sight, but looks quite nice like this.
For the two top connections I have made a similar plate.
Measuring, drilling, sawing and filing, but I got them all right finally, and as solid as a rock.
Next week more!!!
Link to comment
  • 1 month later...
  • 6 months later...
The HAF stacker continues!!!
Thanks to new sponsor Lamptron I've got now two beautiful CW611 controllers This will look great in this build.
SPECS:
Dimension: 5.25″ Bay
LCD Dimensions: 118mm*31mm
Power Output: Up to 36 watts per channel
Control Channel: 6 Channels (All usable in pump, flow meter or fan control mode)
Panel Color Available: Black Anodyzed / Silver
DC Input: +12v (Standard 4 Pin Molex / “D†Connector)
DC Output: 0V- 12V DC
Connectors: 6 X 2510-3pin connectors
Recommend PSU wattage: 550w or higher
At a angle on both sides.
Other side too
After some puzzling with the cables:
And placed the PSU back again
After this I could start with the sides and backpanels. Adjusted and used the original covers for this.
Front cover also back on.
Time for some power.
Link to comment
  • Create New...
Important Information
