Pranja Posted October 27, 2013 Author Share Posted October 27, 2013 PSU cables are shortened and sleeved. New fan got resistor soldered to run quiet and it also has cable in paracord. Now everything looks good without cable mess. Link to comment Share on other sites More sharing options...
Pranja Posted October 27, 2013 Author Share Posted October 27, 2013 Arya now looks quite different, matte black color scheme fits her shape really well. Link to comment Share on other sites More sharing options...
Pranja Posted October 27, 2013 Author Share Posted October 27, 2013 RGB lights: -white -red -green -blue Update will come soon. Link to comment Share on other sites More sharing options...
ggsonic Posted October 30, 2013 Share Posted October 30, 2013 Neat! Loving the simple build. The finished (?) product is much better than I imagined. Why don't you use an acrylic on the sides instead of the mesh? IMO it will look better with acrylic because of the LED's. Another question what does "Arya" mean? Link to comment Share on other sites More sharing options...
Pranja Posted November 1, 2013 Author Share Posted November 1, 2013 Neat! Loving the simple build. The finished (?) product is much better than I imagined. Why don't you use an acrylic on the sides instead of the mesh? IMO it will look better with acrylic because of the LED's. Another question what does "Arya" mean? Thanks! I am waiting for lasercut plexi window for left side panel. Mesh is pleced on righ side panel for PSU cooling. Arya doesn't mean anything, it's just a name that me and my friend came up with. Link to comment Share on other sites More sharing options...
Pranja Posted July 28, 2014 Author Share Posted July 28, 2014 Due to some water spill, I have lost Arya and some peripherals. That took some time to sort out,so here are my last updates. Plexi window is installed in side panel. I menaged to install it without any glue since it is 0,2 mm wider than hole. New RAM, wifi stick and MBO arrived. This time I won't use SFX PSU since I don't have enough time to modify it like last so Pico PSU will be used instead. I am still waiting for 12V adapter to arrrive. HW installed to see how it looks inside case. I still need to cover MBO with carbon foil like last one, resolder and sleeve Pico PSU cables, make custom cables for adapter when it arrives and cover MBO plate with leather if I menage to find it. Link to comment Share on other sites More sharing options...
Pranja Posted July 28, 2014 Author Share Posted July 28, 2014 The work continues. I couldn't find leather for MBO backplate, so I covered it with carbon foil, like I did with MBO. I made custom cables for Pico PSU. Adapter arrived. Link to comment Share on other sites More sharing options...
Pranja Posted July 28, 2014 Author Share Posted July 28, 2014 Arya is completed. Since my last update, I did the following: removed adapter from it's housing, covered it with carbon foil and made custom cables, shortened main cable on Pico PSU, mount side panels adn remove protection foil from plexi. Link to comment Share on other sites More sharing options...
Pranja Posted July 28, 2014 Author Share Posted July 28, 2014 Night pics. Arya and her brothers-Scorpio prototype(left) and Scorpio Mk4 (right). Link to comment Share on other sites More sharing options...
