Jump to content
C3F7OCH3 - An open bath immersion cooling scratch build
Fizzle
C3F7OCH3
This is an initial outline of the project, I will flesh it out soon. Materials are ordered. Experiments under way. Construction begins mid November.
Components will be immersed in and cooled using a fluid that boils at 34C, the vapour will be condensed using water cooling. The case will be half fish tank half water cooling.
Current sketches (these are still evolving):
Goals:
Water cooling of all components without costly water blocks.
Water cooling levels of overclocking.
Portable and safe enough to take to a LAN on the train.
Full sized GPU.
Full sized CPU.
Mini-ITX.
No more expensive than traditional water cooling.
Upgradable.
Items:
Intel 4770k
Asus Maximus VI Impact
16Gb Corsair Vengeance Pro
Random SSD's (for now)
Radeon 6950 with bios mod to unlock voltage and shaders, clocked at 1Ghz (for now, it managed Bioshock 3 at 5760x1080 but it's time for a new card... soon)
Novec 7000
Aluminium
Acrylic
2x dual fan radiators
Pump
Pipes
Custom made condenser
Link to comment
  • Create New...
Important Information
