herwin88 Posted November 29, 2013 Share Posted November 29, 2013 For now i want to present my simple mod Ice Blue Tower with simple mod on watercooling , here is a little teaser for the parts im using (sorry if the pics blurry or not on focus) I will list down the thing i use as material : Material : - 1sheet of acrylic 5mm 2x1m - 2set of acrylic feet - 2m of blue LED strip - 7set of bitspower 10/12 tube fittings - 7 EK PCS 90degree adapter - 2 EK PCS 45degree adapter - 2 Bitspower Multi-Transfer Base (Coupler) - 4 Bitspower Silver Shiny Fillport - 1 Bitspower Mini Valve Silver Shiny - 1 Bitspower male-male g1/4" adapter - 6 Coolermaster Jetflo 120 Fan (Blue LED) Hardware : - Mainboard : Gigabyte F2A85X-UP4 - Processor : AMD Richland A10-6800K - Memory : Avexir 16Gb kit Core Series PC15000 1866Mhz (4gb x 4) - Storage : OCZ Vector 128Gb SSD - Graphics : Radeonâ„¢ HD 7790 Black Edition 1Gb DDR5 - PSU : Seasonic G-550 550W Modular Liquid system : - CPU Block : EK-Supremacy Elite Full Nickel - AMD - Radiator : EK Supremacy Coolstream PE 360 - Reservoir : EK-RES X3 250 - Pump : Laing D5 with EK Supremacy clear plexi top - Coolant : EK Coolant UV Blue (2 bottles) Here is some teaser product some of bitspower and EK rotary the pump im using the water tube new radiator lastly but not the end will be updating for the case mod work soon , for now just the spoiler for parts Link to comment Share on other sites More sharing options...
