Mike Petereyns Posted February 8, 2015 Author Share Posted February 8, 2015 Buzzy with pré assembling the panels to make sure I don't need to drill or cut annything annymore befoure I start powder coating! All panels are removable with torx screws (These will not be the screws I be using after the coating) Link to comment Share on other sites More sharing options...
-=SpH!Nx=- Posted February 10, 2015 Share Posted February 10, 2015 Duuuuuuuude!!!! Awesome!!! How did you do all those curves with the aluminum sheets? Link to comment Share on other sites More sharing options...
Mike Petereyns Posted February 14, 2015 Author Share Posted February 14, 2015 Hey THNX, we used sommething like that Link to comment Share on other sites More sharing options...
Lanto Posted February 15, 2015 Share Posted February 15, 2015 Now this is by far my fav build log can't wait to see it finished Link to comment Share on other sites More sharing options...
Mike Petereyns Posted March 10, 2015 Author Share Posted March 10, 2015 WOW time flies wille having fun...It's abbout time for me to step on the gas here! (my way of working lol) In the mean time I made every hole in place, made the center console more like a motherborad tray and mounted the vesa mount on it to attach the monitor. As for now everything is ready for the powdercoating this week. Wat is still on the plan? *Lasercut the acrylic parts *Assamble the entiere Tri-MAX with all powerdercoated parts together with al te acrylic etc... *Get the hardware and watercooling parts from BitsPower !! *Put the hardware in place with all the watercooling parts. *Connect all the custom sleeved cables + RGB Lightning. *Triple check everything befoure the fotoshoot. I hope to get this all done in abbout 6 weeks (deadline end of april?) Enjoy the last pics before the powdercoating is on...BEY BEY naked allu Mounted the feets Cut the holes for the front connectors, mic, headphone, usb, PSU and VESA mount... Recognize these power/ reset button's ?? PSU mounting holes... Handle for the window panel... VESA mounting for monitor... Motherboard tray, with the cable managment holes and radiator shrouds... VESA mounting bracket THNX to LG they send me one for free Link to comment Share on other sites More sharing options...
Mike Petereyns Posted March 10, 2015 Author Share Posted March 10, 2015 Well all the parts are ready for powdercoating...But I am still not 100% sure abbout the color theme I am going to use?? I will surley use MSI hardware that are red/black colored. * WHITE body / RED acrylic ? * WHITE body / BLUE acrylic ? or * BLACK body / RED acrylic ? * Sugestions ?? Grtzzz MikeMaat Link to comment Share on other sites More sharing options...
Mike Petereyns Posted March 21, 2015 Author Share Posted March 21, 2015 BIG UPDATE !! Say hello the Tri-MAX new powdercoated color ! High quality powdercoating by Flexi Coatings THNX Guys...YOU ROCK ! NETX UPDATE....lasercut Acrylic parts Link to comment Share on other sites More sharing options...
Mike Petereyns Posted April 11, 2015 Author Share Posted April 11, 2015 Well here they are, the laser cutted acrylic parts!! The intention of these parts are to make a light band between the upper and lower part of the case a where the RGB leds shine thru when on ...As you can see in this videoclip. some pictures... Link to comment Share on other sites More sharing options...
Mike Petereyns Posted April 11, 2015 Author Share Posted April 11, 2015 Here you see the top part without the opal acrylic band and lateron with the opal bands. Link to comment Share on other sites More sharing options...
Mike Petereyns Posted April 11, 2015 Author Share Posted April 11, 2015 In the meantime I painted the LG monitor's back panel WHITE to match the other colors, I will use the control button on a diferent place so it can bee reached beter... Link to comment Share on other sites More sharing options...
