Jump to content
Blu ice
iKyaku
The plan:
Cut custom 360 rad hole on top
Cut a window on left panel
custom make shroud to cover PSU and pump
remove all harddrive bays
Plasti Dip case white
Sleeve with paracord
The Parts:
Mobo: Asus z77 sabertooth
Cpu: i7 3770k
ram: 16 gb 4x4 Kingston Hyper X 1600
SSD: Samsung Evo 250gb
Storage: Seagate SSHD 1tb
GPU: XFX HD 7970 Black edition (reference)
PSU: Corsair AX860i
Case: Lian li PC-a71f
Watercooling:
H2o Cooling:
6 SickleFlow 120 2000 RPM Blue LED in push pull config
Monsoon chain gun compressions fittings
Ek 7970 block + back plate
Ek Cpu block acetal
pump swiftech 655
120mm Frozen Q double helix res
XSPC rx360 v3
primochill tubing
lutroO paracord for sleeving
Swiftech 45 and 90 degree adapters and 4 way female adapters
White Plastidip
Link to comment
  • 2 months later...
  • Create New...
Important Information
