Jump to content
Project >>Fusion-xBOT<<
ArMz
Hello guys,
this is my first time join... :happy7:
as u can see my project name is:
PROJECT FUSION-xBOT
What is FUSION?
-Fusion is the process that powers the sun and the stars. It is the reaction in which two atoms of hydrogen combine together, or fuse, to form an atom of helium. In the process some of the mass of the hydrogen is converted into energy.(google.com)
Fusion between two different worlds.
it brings out the best balance of POWER,RELIABILITY,AFFORDABILITY and also overclocking CAPABILITY.
Based on the 'NOISY BOY' from REAL STEEL movie,We recreated the fallen hero to prove that both worlds can be at peace and harmony only at the right hands. whilst being very destructive if it fall on wrong ones,it represents the colours of harmony between all the giants in this particular industry.
stability and performance under one roof becomes our motto in recreating this history,without undermining affordability in owning this 'Beast'.
this is NOISY BOY
my current rig...
so this part will use for this project
my planning
some item is used and some new.
enjoy my drawing and planning first
i will update my worklog..
thanks!
Link to comment
  • 4 months later...
hye uoll..this is my update...it been so long to think about the material and idea..
in this progress i make body work,base for motherboard tray for 2 system and make it 45 degree..
doing loop for both system n leak test..
hope u guys enjoy my pic...
sorry for late update and actually this is my first time joining competition.
post-103892-0-05812000-1465720427_thumb.jpgpost-103892-0-30966900-1465720563_thumb.jpgpost-103892-0-62364900-1465720713_thumb.jpgpost-103892-0-74747200-1465720880_thumb.jpgpost-103892-0-41300900-1465721035_thumb.jpg
post-103892-0-36340800-1465721361_thumb.jpgpost-103892-0-96257700-1465721535_thumb.jpgpost-103892-0-00352300-1465721771_thumb.jpgpost-103892-0-00352300-1465721771_thumb.jpgpost-103892-0-02573200-1465722146_thumb.jpg
Link to comment
this is the specification of my system:
intel system:
i5 4690k
avexir 2x4gb core series
asus sabertooth z97 mark 1
ssd 250gb samsung
seasonic x850 wit fully custom sleeved
AMD system:
fx8350
990fx fatality asrock
thermaltake dps G 1200w
avexir core series 2x4gb blue led
ssd 250gb samsung
watercooling parts:
radiator:
RL series from thermaltake 480x2 240x2
waterblock:
CPU:w2 pacific waterblock from thermaltake
GPU:ekwb for 290 amd
reservoir:
2x PT40 D5
FAN:
COOLER MASTER SICKLE FLOW 4x blue led
thermaltake ring rgb X8
FITTING :
16pcs comp
6 extender
45 degree x4
90 degree x10
TUBING:
16mm OD
12mm ID
cable sleeve:
all from revolozion technologia
THIS IS MY FINISHED PRODUCT!
post-103892-0-04966700-1465736052_thumb.jpgpost-103892-0-44804100-1465736054_thumb.jpgpost-103892-0-99237800-1465736056_thumb.jpgpost-103892-0-66724700-1465736059_thumb.jpgpost-103892-0-47330000-1465736062_thumb.jpgpost-103892-0-15100200-1465736341_thumb.jpgpost-103892-0-51736600-1465736343_thumb.jpg
Link to comment
  • Create New...
Important Information
