Themitichris Posted March 6, 2016 Share Posted March 6, 2016 Hello to all, here I am back with a new project, very different from my standard made-scale "reduced" as the PSPC (computer inside a PS1) and the newcomer, the cub8 (mini-ITX case that I upset the inside to mount a 240mm AIO). I also take this opportunity to say that the project will take inspiration from my current PC, to which I gave a touch of elegance that was missing, Kathrine. TfT, the name of the new project, to which the name refers to the two "towers" on the sides of the case. Here are some render illustrating what I want to do. Sponsor: Config: Case: Cooler Master Trooper Fan: 9x Cooler Master Silencio 120 PSU: Cooler Master v850 CPU: i7 3770K Motherboard: MSI Z77A-GD55 Ram: Transcend AXERAM 16GB 2400Mhz VGA: R9 290 Hybrid Air/Watercooled SSD: 2x Transcend SSD370S 128GB Cable: ModdingStylez Silver/Grey/Black / Coolforce by Nanoxia Liquid cooling: WB CPU: XSPC RayStorm WB VGA: EK thermosphere Pump / Reseivor: XPSC 750 Tubes: Coolforce by Nanoxia Fittings: Coolforce by Nanoxia Liquid: Coolforce by Nanoxia Radiators: 2x 360 60mm The changes that I will do, as you can very well be noted: -double Radiator 360 push / pull -Motherboard Rotated 90 ° with I/O on top -MidPlate Ad-hoc -Colours Main Black / Silver -Sleeve Of all cables Thanks for the attention ------ Pending the arrival of the latest components, I begin to introduce the new SSD's flagship home Transcend, the SSD370S. Some features: Metal body (Hence the "S" placed at the end of the classical model SSD370) Capacity from 32GB to 1TB SATA III 6Gb/s BIG ENTRY: CoolerMaster! Thanks again Alex for giving me this wonderful product of CM's House . Let's start off with the fans, the Silencio FP 120. AAAH, my favorite. CM STORM MECH Complete of I/O inputs 3.0, aluminum, mechanical, fully backlit, fully programmable! Love at first sight! Another pearl Cooler Master, the mouse Reaper! Although it is part of the Aluminium Series characterized backed aluminum Ultimate accessory CM, Pulse-R. The last component of the Aluminium Series There comes a cable with volume control in line to connect our devices to our Headset. The LEDs (Yes, has led) are powered by the USB port. The microphone is removable. -------------------- Here arrived directly from Germany leads the good Matthias The quality is impressive, the cables are very rigid and socks are always clean. ------------------ Now it starts to get serious guys! I removed all the screws conceivable in the case and that is the proceeds Finding myself the skeleton of the Trooper with his nice handle to the frame of the case 3 rivets on each side and two other brackets with 4 rivets hold firmly this tool almost essential. Proceeding with disassembly ... Also outside the front wall containing the box for HDD and ODD cage Finding myself in this situation Here's what I find myself at the end of the day. Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 -------------------- Substantial updates guys! After dismantling the houses have begun to take steps to turn the Motherboard plate And with some work of grinder here is the panel take shape to position the motherboard. Later I got two minimum brackets from the front block to position the radiator Simple, clean and effective. Here's what the case now And here, in brackets ultimate (I served with corners cut to size), the new "front". With its panel Let me know what you think, it is important for me to have a feedback from you --------------------------- Work is under way .. I also drilled the plate behind creating the bracket for the second radiator 360. Subsequently, an L-shaped bracket du serving me I blocked the plate the motherboard to the rest of the case --------------- Update Worklog! Serving me a sheet of zinc courtesy of a carpenter friend of my father: D I have stretched the background that will later-wrapped. I also started to draw prospective slots for SSD. Now I have made this, a cover PSU plywood 4mm, is the first time that I enter into a carpentry work and since I'm used to with Frex,, you can well understand the smell of wood floors that has spread in the room Despite everything, serving me some angular always in wood, came out just like I wanted it! I am satisfied :cooldude: Run-through Wood filler and the holes are gone! See you next time! --------------------------- New updates: I created a second bracket, built primarily for two purposes, in addition to further stiffen the structure: Bring midplate to "level" and supporting a second bracket that you will see later Later I began to place the SSD in place Under the midplate, took into account the dimensions of the tank / pump and power supply, I placed a cage for HDD slide (probably taken from some pre-assembled) Serving me a bracket made from a profile "L" I raised the cage to allow the HDD to enter and exit without hitting the houses Rehearsal (That will clamp removed, the angle must be adapted to the tank / pump) Finally, these are the supports for the SSD viewed from behind: Two bolts M3 holding the SSD retainer to a sheet of 4mm plexy which in turn is held by two other M3 bolts that hold it to the latch plate of the mobo. It is also backlit by a white LED that "separates" in a sense from the background. Any defects in the cuts will be covered by the film which will play all the "background" [imghttp://i.imgur.com/He8DpNx.jpg Preview leds See you next time! Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 ------------------- New Update! Small preview of all the work already done I finally straightened out the plate of the motherboard that was definitely wrong The SSD correctly mounted Second bar coverage Overview Front ------------------------------ Sorry for the long wait, but in addition to the expected new SLR (What I was crazy) I had many commitments. Return to us! Stavo pensando di creare una griglia per il radiatore ed è uscita questa: I do not know yet if I'll put, I've got used to this plexy two days Later, after taking the hand with inventor I created this: And you say: "What?" (To put it clean ) Here it is mounted after doing sheet: (Then it will be colored black) Overview mounted cables and motherboard of "evidence" more decent Also I'm also planning to put the stickers mainly on midplate but that will eventually be scattered everywhere: Tell me what you think, See you next time! Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 ---------------------------------- They're arrived! CoolForce by Nanoxia ---------------------------- The UP that everyone was waiting for! After combining a bit of I finally settled all corners and visible rivets that were ruining the bad plate. Using endless amounts of sandpaper Then I finally started to place fittings creating provisionally the final loop (Then of course I will have to remove all of the color) Pending / video cards leave a tube that runs good area where surely will drop the remaining tubes After that I also start to place the tubes This is love: Second attempt to bend the rigid pipe (The first was released a mixture of sagging accompanied by a bubble because of phono on at maximum asd) Tubes placed Other shortcuts Small overview -------------------- UP After the arrival of the video card (A 7950) I finally finished the loop, the pictures, you judgment I also created a "fullcover" for the thermosphere And instead this is the current situation of the main PC haha ------------------------------ Tell me what do you think Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 --------------------------- Hi guys, here I am back after a lot of time! After the base color I started to decorate a little around the case with the wonderful stickers made in Germany by ModdingStylez, incredible quality! -I Have plugged the hole for the dock on the front panel with a 4-port USB hub. -I Created a counter to run cables from the motherboard to the side, so that they are visible (at least from my perspective) Without another word I leave you to the photos, let me know what you think! ----------------------------- Finally I am back! After modding dedicated to the saint, here is a sink Reference fullcover become a theme! Then mom Transcend provided me these beautiful ram aXeRam that match perfectly with the rest of the project! Here are some pictures: Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 ------------------------------------- First of all I thank my sponsors for their support given to me, in alphabetical order: Cooler Master,soprattutto un grazie a @CM_Alex ! CoolForce by Nanoxia, grazie a Martin! ModdingStylez, grazie a Matthias! Transcend, grazie a Matteo! And finally, thanks to all to have supported me and recommended improvements to the project! Here's the TfT complete and completed! Link to comment Share on other sites More sharing options...
Themitichris Posted March 6, 2016 Author Share Posted March 6, 2016 And here is the RIG! Thank you for watching, we'll saw you in an future mod! Link to comment Share on other sites More sharing options...
