Jump to content
blackNred Wall mount by GamerzNation
Gamerznation
About me :
Vinay Agrawal from India
I build rigs and Workstations for people with name of GamerzNation
you can visit me at https://www.facebook.com/Gamerznationpune/
this build is for watching movies and playing mid level games on TV in the living room!!
This is my try to build a wall mount machine using the folliwing components
asus h97-pro
i5-4440k
corsair vengeance
GTX 650
this build focuses on looks than performance its a light weight machine to add Next gen look to the living room next to the TV.
stay tuned!!
Link to comment
  • 2 weeks later...
Overview
This was my project for a wallmount which will be used for watching movies and playing
light games.Basic theme is Black and Red for this wallmount
Required
1. Wood plank with thickness more than 5mm.(not heavy just enough to hold weights)
2. Acrylic sheets with thickness 3mm or 4mm(not more than 5mm)
3. Basic tools(drilling machine,sandpaper,screwdriver, etc)
4. Soldering gun
5. Led strips
6. Glass holders
7. Carbon fibre vinyl
8. Screws, nut bolts etc .
Components used:
Asus h97 pro
I5-4440k
Galaxy Nvidia GTX650 1GB
1TB seagate barracuda
Xpro Bulldozer 500w
Day 1:
Marking were done on the plank using pencil.every cutout has to be precise for
good wire management.
Use components and mark their outline leaving 1 cm margin.Consider all the wires
going in and out for marking the holes .
Make holes in the centre of each components to make a way for led light .
Day2:
Cutting were done by borrowing wood cutter from power tools store.
Placing every component and checking whether the cutting are perfect or not.
Seems perfect no need of extended sleeves for motherboard power and 8 pin cable.
Day3:
Measure components outline and make a acrylic sheets for it.
Cutting can be done using fine hand saw or dremel.
Link to comment
  • 2 weeks later...
more progress :
DAY 4:
acrylic sheets edge is polished for 45 degree angle for reflecting light
this supporters are used for holding the acrylic panel at place for graphics card support
power button made using screw cover and power switch
 DAY 5:
putting every thing on place.L brackets are used for holding PSU
essentials painted black
DAY 6:
carbon fiber vinyl applied ,sheets are drilled in middle for LED light placement to allow light to enter acrylic
testing sheets look after vinyl
wall mount without led lights
DAY 7:
wall mount with led lights at back installed
gallery_105681_147_293982.jpgDay 8:
Led light on the edges
DAY 9:
after finishing and minor details
thank you guys for taking a look
wallmount at night
thank you guys for stepping by:D
Link to comment
  • Create New...
Important Information
