ad jago Posted February 10, 2017 Share Posted February 10, 2017 Hi I'm from Indonesia... This mod is presented to all pc lovers arround the world... I named this mod water... I'm in love at the first sight with the water cooler long time ago... Almost all part that I used are used part... I believe that moding not about brand new... moding not about hardware... moding is avbout inventing new mod and different from others in common. Moding is about art and taste and you proud of it... SPECS: Case - Cooler Master HAF X CPU - Intel Q9950 Mother Board - ASUS MAXSIMUS EXTREME RAM - 4 x 4 GB GPU - NVIDIA GTX 580 SSD - KingStone HiperX 120 PSU - SilverStone 600 Watt Custom cables - Den's Gear INDONESIA UNIMOD Painting , coating & Sand blasting - 23aprianto INDONESIA UNIMOD Photographer - Dony Da Guar INDONESIA UNIMOD Water Cooling Some Part From Bitspower Some Part From EKWB Some Part From HeatKiller Some Part From Koolance Faser One Liquid Cooler Master HAF X ASUS MAXSIMUS EXTREME NVIDIA GTX 580 Link to comment Share on other sites More sharing options...
ad jago Posted April 9, 2017 Author Share Posted April 9, 2017 cut the side panel, this hard matrial from cooler master nice!!! Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 make hole for side panel Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 thanks fot Tri for great repaint the case and psu Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Bath time Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Make adapter barb fitting maoterboard to hole G 1/4 Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Make hole for 8P Mobo Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Alu lasaer for Logo Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Repaint Fitting EK Link to comment Share on other sites More sharing options...
ad jago Posted May 9, 2017 Author Share Posted May 9, 2017 Thanks for kang Remmi for custom cabe and Sata sleeving Link to comment Share on other sites More sharing options...
