Jump to content
 Hello to all..
This is my 1st time in Cooler Master CaseMOD Series,im so happy to join because my passion is modding..by the way im Homer Dikitanan from the Philippines.im one of the follower of Case/Fan/Cooler/PSU of CM product ever since,now im building a (Tower MOD) catergory.its a simple build with a Regular Computer parts.its a AIR Cooler setup from AIRMAKER 8 with 4 Silencio Fan and the MSI Motherboard and Video Card..
Big Thanks to Cooler Master Philippines =)
Project Name: eknaw saylenshu
Specification
Case - Cooler Master Mastercase 5
Cooler - Cooler Master Air Maker 8
Fan - Cooler Master Silencio PWM 120 4X
Power Supply - Seasonic P660 660W
Fan Controller - NZXT Sentry MIX
Link to comment
ok i will start to mod gain.
this is a deffective NZXT Sentry Mix given by a friend. the 6 sliding potentiometer is broken. Its function as a fan speed regulator is not working. so i went to the electronics store but cannot find the same actual size and value.. To solve the problem i decided to replace the sliding potentiometer with a rotary potentiometer. I also included some mod of this fan controller.
Link to comment
  • 3 weeks later...
  • Create New...
Important Information
