ATEP NURDIN Posted October 6, 2019 Author Share Posted October 6, 2019 apply white as a base paint Link to comment Share on other sites More sharing options...
ATEP NURDIN Posted October 6, 2019 Author Share Posted October 6, 2019 applying sparkling gold paint as the main paint, then coated clear, sorry if there is no photo when I do the painting, because I really do this mod myself. the colors in each photo will look different due to the angle of the photo, but when viewed directly, all colors are the same. Link to comment Share on other sites More sharing options...
ATEP NURDIN Posted October 9, 2019 Author Share Posted October 9, 2019 spruce up the holder and perforating the glass itself, has not been tidied up because it has to measure holes in the case Link to comment Share on other sites More sharing options...
ATEP NURDIN Posted October 9, 2019 Author Share Posted October 9, 2019 I used the original "BATIK" cloth, not a sticker, to beautify the inside of the case Link to comment Share on other sites More sharing options...
ATEP NURDIN Posted October 9, 2019 Author Share Posted October 9, 2019 installed Cooler Master AIO 120 RGB, mod soft tube with 280 radiator, not forgetting the leak test and add dust filter Link to comment Share on other sites More sharing options...
ATEP NURDIN Posted October 9, 2019 Author Share Posted October 9, 2019 towards the finish line Link to comment Share on other sites More sharing options...
