Pascal HERMAN Posted September 29, 2019 Share Posted September 29, 2019 (edited) Welcome ! I plan to improve the cooling abilities of my Cosmos 1000 while keeping unchanged its visual appearance. For its 12th year, I want something big ! This will be a first, I have never changed anything inside, not even installed a custom WC loop, so this project is a real challenge for me. ORIGINAL CASE SETUP MB : Asus Rampage V Edition 10 CPU : Intel Core i7-6850K GPU : MSI GeForce GTX 1080 Ti Gaming X RAM : Corsair Dominator 128 GB DDR4 3200 C16 HDD : Seagate Barracuda 2 TB (x2) SSD : Samsung 850 Pro 512 MB (Sata) + Samsung 960 Pro 2TB (Nvme) PSU : Enermax MaxTytan 1250W 80Plus Titanium Cooling : EKWB custom loop Case : Cooler Master Cosmos 1000 COOLING Current cooling Noctua NH-D15s 2 x Noctua NF-A14 FLX 2 x Noctua NF-S12A FLX Future cooling EWKB custom loop : EK-FB ASUS R5-E10 Monoblock RGB EK-FC1080 GTX Ti TF6 EK-CoolStream CE 420 EK-XRES 140 Revo D5 PWM EK-RES X3 - Tube 250 EK-RES X3 - Long Anticyclone EK-Revo D5 Pump Mount EK-HD PETG Tube 12/16 mm EK-CryoFuel Clear EK-M.2 NVMe Heatsink Noctua NF-A14 FLX, NF-S12A FLX and NF-A14 PWM Chromax Black Alphacool Eisschicht thermal pad 14W / mK Grizzly Kryonaut thermal paste 12,5W / mK Thermaltake Pacific TF1 Temperature and Flow Indicator LIGHTING Alphacool Aurora RGBW Controller 2 x Alphacool Aurora Flexlumière 60 cm RGBW 2 x Alphacool Aurora Flexlumière 30 cm RGBW 4-Way Splitter Cable for RGBW led strip MATERIAL 3 Side panels Cosmos Pure (black) in aluminum 2 Full front panels mesh for MasterBox 5 2 Cooling brackets 420 mm for Cosmos C700P 1 Cooling brackets 280 mm for Mastercase Series TOOLS Dremel Thermaltake bending kit Heat gun Drill Metal saw Ratchet Clamp Motip paint spray Spray gun for painting with 4 flat jet nozzles Glove, mask and protective glasses Ikea coffee table as a workbench AIRFLOW ANALYSIS By default, the Cosmos 1000 is equipped with four fans, a single one bringing fresh air (bottom) and three extracting hot air (two on the top and one on back). The idea is to mount a custom WC loop as well as keeping an afficient airflow in the case. To this goal, we will install on front 3 fans (140 mm) to extract the fresh air and on top a radiator equipped with 3 fans (140 mm) to evacuate hot air. On rear, we will keep the existing fan (120 mm). These fans will be filtered by a mesh panel. A power supply cover will be built with a side panel. It will isolate the power supply from the rest and will receive the storage units (SSD / HDD) on top. The fresh air coming from the front will flow towards the back of the case like a tunnel. The pump will be mounted either on the back panel. Two storage units will be positioned vertically on the back and on the front. MANAGEMENT CABLE The openings 1 and 2 are separed by side panel mechanism (draw in black) which prevents the passage of cable. This problem will be solved by additional openings (draw in yellow) Part 3 will be removed and replaced by a new panel supporting storage units. PANEL CLEANING We start by cleaning the side panels. We remove the frame maintained by 18 screws and the sound-absorbing foam. The double-sided adhesive sticks so well that I took 2 days to make 3 panels. Acetone is a fantastic product for cleaning ! Now the 3 panels are ready for cutting. DISASSEMBLY After some measure, I disassembled the case. Front door Top and front panel Control panel Wrists and Feet Bottom filter Side frames Drawers hard drives REMOVE HARD DISK CAGES & BAY The hard drive cage and the 5.25-inch bay are removed without weakening the structure. CUTTING THE CASE The back, the top and the front panel was cut out, as well as the openings for the passage of the power cables too. Some drilling was done. There is a lot of space now, nice ! RADIATOR INSTALLATION I installed at the top a 420 mm radiator. I lowered the radiator by 25 mm in order not to exceed the available area of the original plastic top panel. As the radiator is a 420 mm one, I had to completely rethink the layout of the front buttons (e.g. power, reset and USB ports). CUTTING PLASTIC FRAME Cutting of the plastic frame is mandatory to fix the new top cover. The side frame is painted with a matte white color. Before painting the frames, I removed the seal around the frame. CUTTING MESH FILTER I removed the perforated metal grid that was fixed to the plastic frame and cut out the frame to put the mesh filter and bracket. CUTTING THE PANEL CONTROL Originally, there were 4 USB 2.0 ports and other outputs that I did not use. I modified the control panel to integrate 2 USB 3.0 ports. The Power and Reset button will be moved forward or replaced by an Alphacool Powerbutton. BUILDING TOP COVER To make the top cover, I used my first previously cleaned panel. Comparison with the old top cover. The top cover once installed with control panel modified. The top cover is painted with a black matt color. BUILDING THE PSU COVER To make the top cover, I used my second previously cleaned panel. Small adjustment. The psu cover is painted in white matt color. BUILDING THE PUMP & STORAGE BRACKET To make the pump / reservoir bracket and storage one, I used my third previously cleaned panel. Depending on the capacity of the hard drives, the mounting holes have not the same layout, hence the 6 holes per disc. The pump / reservoir and storage bracket will be attached to the case. Wrong calculation for storage bracket, start again ! The bracket is painted in matt white color. I bought an anti-vibration HDD mounting kit and a rubber pad for pump bracket to reduce vibration. The rubber pad is installed at the bottom of the pump / reservoir bracket. MANUFACTURING OF NEW ELEMENTS PSU cover Top cover Pump / reservoir bracket Storage bracket Small brackets to install the radiator and the front fans. TEST ASSEMBLY Without painting and definitive fixations, I tested just the assembly to verify that everything was fitting perfectly. UNNECESSARY ELEMENTS Beautiful sound-absorbing foam - sadly not used. Obsolete USB 2.0 port and other inputs / outputs from another era - as well as the associated cables. PAINTING WORKSHOP The front fan mount (top) has been painted in 2 colors. The front in matt black and the inside in matt white to built an harmony of colors. All the holes and sharp edges were sanded with sandpaper for an flawless result. I have put neodymium magnets on the front fan mount to be able to remove it when cleaning The other bracket was fixed at the bottom. Another bracket for the radiator was fixed to the back. Finally, I used 7 spay bombs : 2 Primers, 3 Matt White, and 2 Matt black. I still have 2 spray bombs glossy black. It is emptying at a speed these little bombs ! PAINTING WRISTS & FEET The wrists and feet are painted in matt white color. PAINTING THE DOOR The door is painted in matt white color. PAINTING SIDE PANELS The side panels are painted in matt black color. ASSEMBLY MONOBLOCK CPU & FULL COVER GPU Motherboard without heat sink Heat sink and RGB part Motherboard with monoblock CPU Graphic card Without heat sink Thermal grease Thermal pad Fittings Alphacool Eiszapfen Pressure Valve. I bought a power adapter for Temperature and Flow Indicator to facilitate cable management. I will use a 3M Velcro to fix the SSD. CUSTOM LOOP SCHEMA INTERMEDIATE PHOTO Without mesh filter and custom loop. FINAL RESULT BEFORE Edited March 31, 2020 by Pascal HERMAN 1 Link to comment Share on other sites More sharing options...
Pascal HERMAN Posted October 23, 2019 Author Share Posted October 23, 2019 (edited) I thank you for your support. I spent a lot of time on this project, I do not regret my investment in tools, materials, components and various accessories. I wanted to do something clean, rather sober but classy and efficient in cooling, with a good cable management. I hope you enjoyed my work, that you liked the project and that it gives you ideas for your own realization. Thank you French traduction : Je vous remercie pour votre soutien. J'ai passé beaucoup de temps sur ce projet, je ne regrette pas mon investissement en outillage, matériaux, composants et divers accessoires. J'ai voulu faire quelque chose de propre, plutôt sobre mais classe et efficace en refroidissement, avec un bon câble management. J'espère que vous avez apprécié mon travail, que le projet vous a plu et que cela vous donne des idées pour votre propre réalisation. Merci The winners : here Edited December 29, 2019 by Pascal HERMAN Link to comment Share on other sites More sharing options...
Chris Holmes Posted July 7, 2020 Share Posted July 7, 2020 WOW!! I'm using a Cosmos II at the moment, was browsing the Forum and I saw your reference to this build page...and all I can think of to say is: WOW!! Great work, dedication and result...really impressive! I hope you'll continue to love this fantastic custom job for many years to come!! SENSATIONAL... 1 Link to comment Share on other sites More sharing options...
