Jump to content
Here we have our entry to the CMWS 2024, the W-Frame.
The components that we are aiming to use for this project are as follows.
Main components:
CPU: AMD 7800X3D
Mobo: Asus ROG Strix X670E-I
GPU: Asus TUF RTX 4090 OC
Memory: G.Skill Trident NEO 64GB 6000MT/s CL30
SSD: Kingston Fury Renegade 2TB
PSU: Cooler Master V SFX PLATINUM 1100
Water cooling:
CPU: Alphacool Core 1 Aurora Black
GPU: Alphacool Core Geforce RTX 4090 Strix + TUF with backplate
Radiator: Alphacool NexXxoS XT45 Full Copper 360mm
Radiator: Alphacool NexXxoS XT45 Full Copper 200mm
Pump/Res-combo: Alphacool Core Flat Reservoir 240 (inkl. VPP Pump)
Res: Alphacool Cape Corp Coolplex Pro 25 LT
Fittings: Corsair hardline fittings and adapters
Concept:
The main idea here is to create something really unique and eye catching by placing most of the hardware outside of the case in a sideways w pattern and to not hide cables or tubes but instead highlight them in the main structure of the frame. The case will be constructed out of mostly aluminum and acrylic with the odd 3d-printed piece here and there to assist with cable management.
  • Like 4
Link to comment
At this point we are still in the designing phase of the build and right now we are tackling the task of how to secure the extrusions together without disturbing the outside silhouette  of the main tower.
Option 1, 3d-printing brackets which would make it easy to position mounts for the acrylic aswell but they might look a bit intrusive.
Option 2, Metal brackets that makerbeam sources for attaching beams together. They might be smaller in profile and stronger but dont offer any mounting for the acrylic so those will have to be separate pieces.
Thoughts ? :)
A random render which shows the plans for the backside of the mobo and the cable routing.
  • Like 3
Link to comment
So the design is progressing one bracket and fastner at the time :)
Since last time ive been working on the brackets for the cables and the mount for the reservoir in the top. Next thing will be to figure out the bottom compartment i think.
Some renders :)
  • Like 1
Link to comment
  • 4 weeks later...
Quick little update from Webhallen Config.
Its vacation time here in Sweden atm so little work is going in to the designing of the build but some is done remote from the comfort of my home :)
I ordered a startkit from Makerbeam so i can try out the tolerances of the 3d-printed parts and for the most part everything seems to fit. The regular startkit did not come with the t-slot nuts though so i had to order them separatley.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
Important Information
