shadewalker Posted July 3, 2009 Share Posted July 3, 2009 hey guys so here's what the cooler monster looks like i'll start in reverse order of the mods... the lcd panel.. here's how its started i stripped the panel out of its shell... then extended a few cables to make sure nothing gets pulled off then case the pcb behind the lcd to prevent any short circuit and laced the lcs in place of 2 drive bays since it was a 6" wide lcd the fit was perfect.. and here's what it looks like at night now the insides i changed the led's on the front and added a few on the side fan to match the color of aquagate max... a better look of the inside added some green uv paint on the top and some blue on the bottom hard drive bracket just for experimentation and here's a final pic of what it looks like in the end Link to comment Share on other sites More sharing options...
biggatomic Posted July 3, 2009 Share Posted July 3, 2009 very nice Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 3, 2009 Share Posted September 3, 2009 looks very nice like the lcd whats on the front.... looks very clean inside what more can i say with only 1 page to work with thanks for sharing Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 30, 2009 Share Posted September 30, 2009 GOOD LUCK TO YOU AND TO ALL CONTESTANT, IT WAS GREAT TO KNOW YOU Link to comment Share on other sites More sharing options...
