MonsterMawd Posted February 6, 2010 Share Posted February 6, 2010 I'm installing the 120mm Scythe cooling fan and grill in the side panel of a Cooler Master Cosmos case. List of Tools Needed Power drill 3/16" drill bit Measuring Square or Ruler Pencil or Pen Painter's Masking Tape Center Punch Phillips Screwdriver "SEM brand Self Etching" Primer "Plastikote brand Silver Automotive Enamel paint 1x Black 120mm Round Hole fan grill 4x #10 x 5/8 self tapping fan screws Greenlee Knock out Punch Catalog Page http://www.mygreenlee.com/products/Holemaking.PDF Greenlee part # 730EBB-120. Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new. I painted this Black http://www.mnpctech.com/120mm_Custom_FanGrill.html 120mm Round Hole fan grill with Silver automotive aerosol paint. Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 10, 2010 Author Share Posted February 10, 2010 This Cosmos grained aluminum panel look so nice. It served as a great canvas to compare how our machined aluminum 120mm grills look. Heres how the panel looks with 120mm "Turbo" machined aluminum fan grill The panel with 120mm "Nautilus" machined aluminum fan grill Link to comment Share on other sites More sharing options...
Ragdollcatman Posted March 2, 2010 Share Posted March 2, 2010 Nice, here is my Cosmos 1000 side panel mod - nowhere near as pro as yours, but we can't afford the proper hole cutter bits and those lovely fan grills etc I haven't seen anywhere in the UK And my other mod for the Striker II Formula (or any other mobo using those handy but damn annoying LCD displays) Link to comment Share on other sites More sharing options...
Ragdollcatman Posted March 2, 2010 Share Posted March 2, 2010 BTW, yes, I know theres a hole in one of the foam filters - I did it by accident - have some spare filters, so will replace when I can be bothered too - like the foam actually stops anything. Link to comment Share on other sites More sharing options...
