Jump to content
CM 690 II ADVANCED from Italy!
maxmax80
Hi!
I'm max from italy and this is my CM 690 II ADVANCED project!
Cpu: Intel Xeon L3110 (45 Watt TDP)
Mobo: Msi p45 diamond
Ram: Kingston LoVo ddr3 4 giga kit 1,25 vram
Ali : Scythe Stronger 600W plug-in modulare
GPU: MSI-Ati Radeon R5450-MD1GH (passive cooler)
APU Internal: MSI-Creative® SB X-Fi Xtreme H/W Audio Card PCI-ex (MS-4132 bundle with P45 Diamond)
APU Esternal: Focusrite Saffire Firewire Sound Card Pro
Hdd1: WD Velociraptor 74Gb-10000rpm
Hdd2: WD Velociraptor 150Gb-10000rpm
Hdd2: WD Caviar green 1Tb-7200-64mb (2 plates)
Dvd reader: Samsung SH-D163B black sata
Dvd recorder: Samsung SH-S223C black sata
Scythe Card Reader Combo Floppy
Monitor: Hanns-g HX191DP 16/9 5ms full Hd
Case: Cooler Master 690 II Advanced (obviously!!) + plexiglass side windws
CPU Cooler: Noctua NH-U9B SE2
Rheobus:
- Cooler Master Wind Rider PWM hub
- Nanoxia PwmX Controller (for both Noctua NH-U9B SE2 fans)
- Sunbeam Theta pci controller (per monitor rpm fans by tacho cables from Wind Rider)
Fans:
- Enermax Cluster UCCL12 PWM - 120mm (front)
- Noiseblocker Multiframe M12-P PWM - 120mm (down)
- Akasa Apache 120mm PWM Fan - camou (top I)
- Arctic Cooling Arctic F12 Pro PWM - 120mm (top II)
- Scythe Kama DFS122512L-PWM 120mm (back)
- Silverstone Nitrogon NT07 AM2 PWM 80x80x15 (side dx back mobo)
- Arctic Cooling Arctic F12 PWM - 120mm (side sx fan I)
- Scythe Slip Stream PWM - 120mm (side sx fan II) (I sacrifice it in plexiglass windows)
and
- Coolink SWiF2-120P Retail 120mm - PWM (middle case)
- SilenX Fan Ixtrema Pro IXP-74-14T Thermistor - Tachi 120mm (with termal sensor for Hdd)
- Silverstone Suscool 81 80mm Thermal control (with termal sensor for NorthBridge)
additional accessories:
- Scythe Kama stay (for Coolink fan in the middle)
- Sunbeam Wherever Pci Rack
- Thermaltake AquaBay M3 CL-W0031 + Pump SE 90 L/hr (for future NorthBridge water cooling system)
- Akasa fan adapter 60>80 (for Silverstone fan on NB)
- Demciflex magnetic filters
- Silicone antivibrations for PSU
- Rubber screw for all fans
- Revoltec double withe neon
- Nzxt extension cable ATX / EPS 25cm - premium sleeved black
- Various tachometer and pwm extension cables
total power consumption: 50 watt idle with neon off, 70 watt idle with neon on
Link to comment
scythe psu and noiseblocker fan both with anti-vibration rubber/silicone frame
kama stay and revoltec neon controller with invisible cable management..
Sunbeam Pci rack and first neon inside it
nanoxia Pwmx and second neon behind it
Msi Green Power genie that separe all
sata rounded different colour cable to identify immediately hdd
optimal symmetrical cable management of optical drive section
Akasa & arctic cooling pwm/pst on top
Link to comment
back cable management
detail
Y cable modified for drive Noctua tachometers fan by Nanoxia pwmx (connector to wind rider connected to mobo pwm channel) and control/monitor first fan by Msi utilites and second fans only monitor by Sunbeam theta (but controller by Msi utilities)
Link to comment
  • 1 month later...
  • Create New...
Important Information
