herculess Posted April 18, 2011 Share Posted April 18, 2011 Hi all After several days of designing my new pc case, i would like to present you some photos from Sketchup. I would like a case which would be impressive by its size, with edges and simple minimal design. The lighting of the case will be the most important part of the construction, as the lighting effects will reveal the additional dimension and complete the minimal frame. Materials: Mostly i will use "warm" materials such as wood (for the frame), plexi glass or mat glass and aluminum for the details. System: As I don't have any sponsor, the system will be my one year old desktop computer with the following parts MoBo: Gigabyte GA-770TA -ud3 CPU: Athlon II X4 2,9GHz RAM: 2x2 GB Kingston and Corsair GPU: Sapphire Radeon 4850 1GB HD: WD Black - 750 GB Cost: With concept work of pc case, i will try to give an opportunity for those modders who are not able/or want to spend a lot of money but want to have a handmade creation, learning how to choose low cost materials and build it with less than 100 Euros. Duration of work: Approximately 2 weeks, but always until the last day of the deadline ! Photos: Link to comment Share on other sites More sharing options...
