Corsaronero333 Posted October 21, 2012 Author Share Posted October 21, 2012 Steel tubes 12mm Link to comment Share on other sites More sharing options...
Fifas Posted October 21, 2012 Share Posted October 21, 2012 That's freakin awesome! Congrats Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 25, 2012 Author Share Posted October 25, 2012 That's freakin awesome! Congrats thanks Fifas Link to comment Share on other sites More sharing options...
frozensnail Posted October 26, 2012 Share Posted October 26, 2012 The cooling reservoir with the steel tubes does look very cool indeed. I bet measurements have to be 100% and no over tightening of the domed fasteners to achieve this custom reservoir, may I ask if it ‘leak’ tested ok? Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 27, 2012 Author Share Posted October 27, 2012 The cooling reservoir with the steel tubes does look very cool indeed. I bet measurements have to be 100% and no over tightening of the domed fasteners to achieve this custom reservoir, may I ask if it ‘leak’ tested ok? Thanks for the compliments, the measures for tightening have 2mm margin, and the seal is perfect, at present no loss Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 27, 2012 Author Share Posted October 27, 2012 Test light tank Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 27, 2012 Author Share Posted October 27, 2012 Change fittings Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 27, 2012 Author Share Posted October 27, 2012 Today I fixed a problem of the tank, I added a ring of steel to compress the rubber evenly without first ring after ring mounted Tank finally over Now we continue with the set of mod Link to comment Share on other sites More sharing options...
steff345 Posted October 28, 2012 Share Posted October 28, 2012 that honestly is one freaking awesome work there - keep it up and definitely would be looking out for more updates!! Link to comment Share on other sites More sharing options...
Corsaronero333 Posted October 31, 2012 Author Share Posted October 31, 2012 that honestly is one freaking awesome work there - keep it up and definitely would be looking out for more updates!! Thank you steff345 Link to comment Share on other sites More sharing options...
