jones965 Posted September 12, 2012 Author Share Posted September 12, 2012 Coming along well, like the idea for mounting the radiator at the side of the chassis. Also good job making the rad cowling / guard. Thanks! UPGRADE!! The next step was a separator box for the PSU. Because of the front radiator, a could not build a straight box, it had to be thinner in the front. Here I used my favorite 1 mm aluminum plate, designed the side of the cover to be easily removable If I want to swap the PSU. Here I got to the point, when I had all the main inside and outside elements together, but the whole case needed to be tuned together. First I sanded the custom metal parts and painted with titanium base color. After three days sanded it once more, and gave it a matte finish layer. Unfortunately, the finish layer started to solve the basic layer. Link to comment Share on other sites More sharing options...
jones965 Posted September 16, 2012 Author Share Posted September 16, 2012 UPGRADE!! My next idea was to cover the parts with carbon-fiber like vinyl film. Link to comment Share on other sites More sharing options...
jones965 Posted September 18, 2012 Author Share Posted September 18, 2012 UPGRADE! When I finished the work, it looked cool, so I decided to continue on the outside. I covered the glossy top control panel, preserved the Cosmos logo here, then I use a brighter carbon-fiber film on the sides. Link to comment Share on other sites More sharing options...
jones965 Posted September 24, 2012 Author Share Posted September 24, 2012 UPGRADE! The next element was an SSD holder. I cut three Plexiglas pieces, polished their edges, and used LED-s to light them, so I got a cool edge-lit effect. Link to comment Share on other sites More sharing options...
jones965 Posted October 1, 2012 Author Share Posted October 1, 2012 UPDATE! At this point I started to install the water cooling. My first task was to upgrade the Aquaero 5 controllers cooling. I cut an old, copper Socket 478 to suitable form, and painted it black, to blend in. Cooling remove. Link to comment Share on other sites More sharing options...
frozensnail Posted October 3, 2012 Share Posted October 3, 2012 The custom made panels look really well made & the carbon look covering is very well done, can't wait to see more of your work Link to comment Share on other sites More sharing options...
MonsterMawd Posted October 3, 2012 Share Posted October 3, 2012 Great job so far, original cosmos case provides challenge for space behind the Mb Link to comment Share on other sites More sharing options...
jones965 Posted October 3, 2012 Author Share Posted October 3, 2012 The custom made panels look really well made & the carbon look covering is very well done, can't wait to see more of your work Thank you, the final result turns up soon. Link to comment Share on other sites More sharing options...
jones965 Posted October 3, 2012 Author Share Posted October 3, 2012 Great job so far, original cosmos case provides challenge for space behind the Mb Yes, the cable management is quite challenging, I cut extra holes on the motherboard tray. Link to comment Share on other sites More sharing options...
jones965 Posted October 8, 2012 Author Share Posted October 8, 2012 UPGRADE! I installed the thermometer to the top radiators exit pipe. The pump find its lace in front of the PSU, I used 19/13 transparent silicone pipe for connecting the components. The following hardware was installed: Motherboard: Asus Rampage IV Formula CPU: Core i7 3930K Memory: Gskill Ripjaws 2133 MHz 4 x 4 GB VGA: Asus HD 7970 System drive: OCZ Vertex 2 2 x 64 GB RAID Storage drive: OCZ Octane 120GB PSU: Cooler Master Silent Pro Hybrid 850W - thank you Cooler Master Hungary! Link to comment Share on other sites More sharing options...
