mindphaser7 Posted September 7, 2012 Share Posted September 7, 2012 Hi everyone. I am an entry-level modder from Ukraine and this is my second modding project. I have no sponsors, so project budget is limited and hardware is not state-of-the-art. CONCEPT If you ever play Half Life 2, you have to remember Alliance turrets. This project will be a console type PC, with optional table mounting. Not an exact copy, but very close to the original ceiling turret. And maybe it will looks like a HL3 turret, who knows? So let’s start making a Combine Turret. Here is the hardware list: CPU cooler: Cooler Master Gemini II M4 MB: Gigabyte H55N-USB3 CPU: Intel i3-550 MEM: Hynix DDR3 2x2G 1333MHz CL9 PSU: Flex-ATX Seasonic SS-250SU GPU: Asus HD5770 512Mb GDDR5 HDD: SATA 160Gb Samsung SpinPoint F1 8Mb DVD: DVD-RW SATA Sony Nec Optiarc AD-7690H (slim slot-in) CASE: full custom (picture is not available now) Link to comment Share on other sites More sharing options...
mindphaser7 Posted September 8, 2012 Author Share Posted September 8, 2012 The main inspiration object is Combine Ceiling Turret: So I’ve plane to make the case not in the style of the game but highest possible close to original source. Also inspiration objects - Alliance turrets: Layout 2D layout: Comments are unnecessary - all self-explanatory 3D layout: The frame going to make from aluminum angle bars, side panels - glass-fiber plastic, and the rest during the process. Link to comment Share on other sites More sharing options...
mindphaser7 Posted September 12, 2012 Author Share Posted September 12, 2012 To initiate the process make a power supply unit angular mounts: Adjust the attachment holes and fan cut-out: Time to handle a framework. The problem is that the case almost have no right angles, all surfaces are sloped - will have some fun The pair of rear frame’s profiles: Manual bending: Angle revision: Forming the rear side of the frame: HDD mountings: Mid frame profiles cutting: Link to comment Share on other sites More sharing options...
mindphaser7 Posted September 18, 2012 Author Share Posted September 18, 2012 Trying on the motherboard with box CPU cooler (CM Gemini II M4 is not yet redy) Rear panel cutouts: Have to make cutouts for memory modules too: Frame assembly. The frame is almost ready, can place the hardware. Installing PSU: PSU cable assembly: Here is the secret ingredient - furniture hinge. “What for?†you can ask. The fact that the lid will be a separate structure that is rotated forward relative to the frame. Lid close position: Lid open position: So, a furniture hinge serves as a pivot joint. A video card housing will slide back through the guide: Link to comment Share on other sites More sharing options...
mindphaser7 Posted September 21, 2012 Author Share Posted September 21, 2012 Graphics card and cooling system added for the sake of completeness: Now the PSU, MB & HDD fixed Dimensions check Link to comment Share on other sites More sharing options...
mindphaser7 Posted September 27, 2012 Author Share Posted September 27, 2012 Its time to modify the low-profile Cooler Master Gemini II M4 CPU Despite the fact that is the lowest Cooler Master cooler, I have to make it even thinner. First, remove the fan, and tilt radiator: In rotate position heat pipes run into the capacitors and the cooler base not in contact to processor Need to raise the cooler on the heat sink: Tinkering heat sink and heat pipes, a second attempt To warm up the heat pipes cooler is placed in a container with boiling water on the gas stove Heat sink roasting Cooler assembled Modified CM Gemini II M4 tests on OCCT v.3.1.0: With stock fan - better then original! Passive –fail (even without load): With Titan TTC SC-04 blower That’s my choice: Link to comment Share on other sites More sharing options...
mindphaser7 Posted October 1, 2012 Author Share Posted October 1, 2012 It’s time to make a frame holder. The joint plate at first: Made from 1,5mm thickness steel: It attached to rear part of frame: Lets take a closer look at the mounting cantilever: It’s made from steel perforated plates and aluminum angles: Trapezium-shape part cut-off from box-shaped level tube by the actual size printed template (do you think it’s too big for mini-ITX case?) : Vee-type part in closer view: The video output extension cords and power cord will be tracked inside. Something like this: Link to comment Share on other sites More sharing options...
mindphaser7 Posted October 9, 2012 Author Share Posted October 9, 2012 It is time to prepare a little bit of aluminum sawdust. Start to make a MB rear panel cover. The top canopy at first: Then side parts: Testing: Side parts will be removable, attached with screws. Link to comment Share on other sites More sharing options...
mindphaser7 Posted October 16, 2012 Author Share Posted October 16, 2012 As I wrote early, video card housing will slide back through the guide. Telescoping rail guide (from furniture set) need to be shortened at first: Both original and shortened guide: Close position: Open position: Fixing at mounting angles: Link to comment Share on other sites More sharing options...
mindphaser7 Posted October 22, 2012 Author Share Posted October 22, 2012 Swivel lid will make from fiber-glass plastic. Marking: Ventilation holes contours marked trough laser printer paper copy and electric iron: However forgot to mirror the image (smile) Predrill: A hacksaw and needle files working result: Link to comment Share on other sites More sharing options...
