Paslis Posted September 23, 2013 Share Posted September 23, 2013 Hey all, This is my entry for the CM 2013 Contest. Many people asked me to do an industrial build so i think its time to do one.This time no sanding and painting just plain stainless steel. Ignotus stands for unknown as i dont know what im gonna make this time i lett my hands do the work and i watch if its any good what they make. This is the only drawning i have. For this project im gonna use stainless steel only and no sanding and all the welds will be visible. The hardware : Cpu : intel core i7 980x Mobo : Gigabyte G1 Assasin Gpu : Gigabyte GV-N780OC-3GD Mem : Corsair dominator GT Hdd : 2 x 1TB Ssd : 1x 256 GB Psu : Coolermaster V1000 The cooling : Cpu : BP-WBCPUIBA-CUMBKSL Gpu : BP-WBVGNGTXTITANNPACIBK-SL Res : BP-WTZM400P-BK Rad : 1x 360 Pump : 1x D5 Fans : 10x CM Jet Flo Fittings : BP-WTP-C47 Pipe : 12mm copper Time to get started. Some hardware pictures. Lets do some work.First i start to make the parts for the base. All parts together. Time to weld it all together. This is how it looks at the moment. This was it for today and more to come. Link to comment Share on other sites More sharing options...
Paslis Posted September 28, 2013 Author Share Posted September 28, 2013 Update 1. Today it was time to do some work on project Ignotus.First some new hardware. Now its time to do some work. First lasercut 11 spacers made off 2mm stainless steel. Then i cutt 2 axels of 10mm stainless steel and bended and welded all the parts together. Then i cutt 2 pieces square 20x20mm stainless,drilled,and welded the pieces. The parts are finished now so its time to weld them to the base. Mounted the reservoir and this is how it looks so far. More to come. Link to comment Share on other sites More sharing options...
Paslis Posted October 13, 2013 Author Share Posted October 13, 2013 Update 2. This weekend it was time to do some modding again but first some pictures of new stuff. Time to do some work.First i cut the pieces i need from 2mm stainless steel. The i bend the pieces. Then i made the mounting points to mount the front panel.. Test fit. The next job was the fangrill.I welded the grill and after that i cut,bend and welded the 10mm hooks onto the grill. This is how it looks at this moment. More to come. Link to comment Share on other sites More sharing options...
IVANICS Design Posted October 13, 2013 Share Posted October 13, 2013 Looks great to me... Link to comment Share on other sites More sharing options...
Paslis Posted October 14, 2013 Author Share Posted October 14, 2013 Thanks IVANICS. Link to comment Share on other sites More sharing options...
Paslis Posted October 19, 2013 Author Share Posted October 19, 2013 Update 3. This weekend it was modding time again.This time i made a psu cover and finished the front. The parts im gonna use. Some bending. Bend the psu cover and weld it. Then i took some 10mm stainless rods and cut,bend and welded them. Ready to weld the cover on the frame. Now its time to finish the front.First i made a extra detail. Then i made the side pieces and they also cover the top.Then i made the mounting holes and welded the pieces on the front cover. the result. This was it for today. Link to comment Share on other sites More sharing options...
Alexander Hede Posted October 24, 2013 Share Posted October 24, 2013 Looks great Paslis! I really like the shape of it Link to comment Share on other sites More sharing options...
Paslis Posted October 26, 2013 Author Share Posted October 26, 2013 Thanks Ace_finland. Link to comment Share on other sites More sharing options...
Paslis Posted October 26, 2013 Author Share Posted October 26, 2013 Update 4. Today it was time to do some modding.This time i made the mobotray. First i did some measurements and then some drawning and after that some cutting. Then i tapped all the holes with M3 and i usedf a drill.This saves a lot of time but be carefull keep the drill straight and use tap oil. I also made a small movie for the people who want to try it. After that i bend the tray and used temporary bolt for test fitting the mobo. Then i used some 10mm stainless rods and cut them to the right lenght did some bending and welded them on the tray. Time to weld the tray on the frame. Mounted the mobo and this is the result. This was it for today. Link to comment Share on other sites More sharing options...
ggsonic Posted October 30, 2013 Share Posted October 30, 2013 Me likey! How do I subscribe to this thread? Link to comment Share on other sites More sharing options...
