E x e Posted October 30, 2013 Share Posted October 30, 2013 Heavy duty, nice Link to comment Share on other sites More sharing options...
Paslis Posted October 31, 2013 Author Share Posted October 31, 2013 Me likey! How do I subscribe to this thread? Thanks Onyx and below on this page there is a subscribe line. Heavy duty, nice Thanks Exe Link to comment Share on other sites More sharing options...
Paslis Posted November 10, 2013 Author Share Posted November 10, 2013 Update 5. This weekend it was time to do some modding.The intension was to get started with the hdd brackets but i got a strange feeling about the psu holder so it had to go.This also gave me the idea to change the design. The psu bracket. Then i removed the psu holder and covered my tracks. Then i changed the design and took some stainless 10mm rods and bended them and welded them to the frame. Mounted the front back on and this is how it looks. Finally i like it and i also got some crazy ideas on how to continue. More to come. Link to comment Share on other sites More sharing options...
ASOUTER Posted November 10, 2013 Share Posted November 10, 2013 Looking forward to seeing those crazy ideas Paslis, Is it me or does this forum seem very quiet ? (guess it's the competition side of things) Good luck this but I'm guessing you won't be needing luck ... brilliant piece of design man Link to comment Share on other sites More sharing options...
Paslis Posted November 17, 2013 Author Share Posted November 17, 2013 Looking forward to seeing those crazy ideas Paslis, Is it me or does this forum seem very quiet ? (guess it's the competition side of things) Good luck this but I'm guessing you won't be needing luck ... brilliant piece of design man Thanks ASOUTER and yes this forum is very quiet and i also guess its the competition side of things.Thanks again and sure i will need luck. Link to comment Share on other sites More sharing options...
Paslis Posted November 17, 2013 Author Share Posted November 17, 2013 Update 6. This weekend i made the hdd brackets.I used 2mm stainless for the brackets and a 10mm rod. First i cut and bend the brackets. Then i spotwelded them to the frame and after that i finished welding them. The looks. This was it for today.More to come. Link to comment Share on other sites More sharing options...
Paslis Posted December 1, 2013 Author Share Posted December 1, 2013 Update 7. This weekend it was time to do some modding.The psu didnt look right so i had to give it an industrial look to fit in with the design. First i made the bottom plate from 2mm stainless and made de mounts for the print. Then i made a frame of 10 mm stainless rods and a fan mounting bracket. This is how it looks with the print mounted. Its not ready yet so more to come. Link to comment Share on other sites More sharing options...
Paslis Posted December 15, 2013 Author Share Posted December 15, 2013 Update 8. This weekend it was time to work on the psu again. Lets do some work.I have quite a few pictures so this time i let the pictures do the talking have fun watching. The psu is almost done so i can almost move to the next part. More to come. Link to comment Share on other sites More sharing options...
IVANICS Design Posted December 15, 2013 Share Posted December 15, 2013 This was my face when I saw your PSU: It's rock! Keep up the good work! Link to comment Share on other sites More sharing options...
Paslis Posted December 16, 2013 Author Share Posted December 16, 2013 Thanks a lot IVANICS. Link to comment Share on other sites More sharing options...
