Jump to content
(Scratch Build) Carbon Steel **FINISHED**
mechabearshark
b]Carbon steel[/b]
scratch build
Steel construction, air cooled, Budget Build.
Concept:
Angular steel construction with hand forged scrollwork and chain mail.
Invert ATX Mounting
straight through flow design.
relocated optical, fan control, usb panel
Intel I5-2380
Biostar TZ77B mother board
Gigabyte gt430 2 gig
8 gig Patriot sector 5
WD caviar green 500 gb HD
Cooler master Hyper n520
cooler master 120 fan x2 (bought about a year ago forgot what model)
cooler master master sickleflow 120
4x unknown 80 mm fans
need to Purchase:
New PS
ssd
cooler master hyper t-3 (Base for custom GPU cooler)
I will start you out with my filthy cluttered work area
start point was a Lian li Pc-60
using mb tray and HD cage Panels will be used for scrap in build what ever I might need
crappy phone pic
front grill
Link to comment
  • 2 weeks later...
  • Create New...
Important Information
