mechabearshark Posted December 9, 2013 Author Share Posted December 9, 2013 I got a lot of stuff done today and made some real progress, I finished up welding up the cage and did some test fitting cut the side panels including the panel window I evan go the top panel cut some glamour shots then I cut the side panels, the window and the top panel I am re using the aluminum from the lian li case I started from. than I layed everything on top of each other to get an idea what it may look like Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 finally back at it... feeling the dead line though first up this is a die I made for leafing.. you will see more of that latter here is my thumb after I hit it with a three pound hammer here is my forge.. didn't have time to complete my charcoal to gas conversion so I using my cylinder with char... here I am doing some test fitting curring the interior paneling finished welding fan mounts rear Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 I got made so I lit it on fire putting a black patina on the frame I had a video of the fire but it wasn't interesting... just a fire. the cage is black now cur the corner panels and baked them... hard to photograph but the have a feint blue colloring Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 Super big hot update!!11 aka blacksmithing time! I love burn days I just don't get many of them..... here is my anvil ready with my tools my charcoal forge making S scrolls more heat them up for wax patina Jobs done I am exactly this dirty and I got my sleeving supplies Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 Today I finished drilling the side panels and windows and finished my fron facia I am going to weld everything on tomorrow so there will be another big update hopfully ill be out of the manufacturing stage. facia corners cut I use tape to help hold the piece while I tack them in watch out shitty welds ahead cleaned up after baking ... front panel after baking and chainmail installed Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 PIctures....... if its not against the rules i am going to take more pictures tomorrow in the day light to show the color of the steal its time for a show and sleep i built this while working 12 hour days and finind time at night to slowly work on this.....i see mistakes right noe maybe tomorrow int the light i can show what i love about this case Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 wanted to share more pictures Link to comment Share on other sites More sharing options...
mechabearshark Posted July 25, 2014 Author Share Posted July 25, 2014 been running the case for 5 days now... GPU is running about 10 degrees cooler it usually between 50-52 Link to comment Share on other sites More sharing options...
