Jump to content
[Tower Mod] Project Imagination by adamski07 [Completed]
Adam
Adamski Mod Facebook Page
Rig Noobies
THE CASE
COOLER MASTER STORM TROOPER
"Storm Trooper. Join the mobile infantry."
Specifications:
Case: CM Storm Trooper
PSU: CM V series 850W
Motherboard: Asus Formula VI Z87
CPU: Intel i7-4770k
GPU: SLI GTX 780
RAM: Corsair Vengeance PRO
SSD: Samsung 830 256GB
Cooling: Custom Liquid Cooling
I'm finally back again with a new case mod project! Some of you may know me already after my first project where I won the OCN's March 2013 MOTM. Now is the time for new project on the CoolerMaster CM Storm Trooper Case. :)
Project Imagination is going to be the line up of my upcoming mods.
Key Features:
1. Custom Reservoir
2. Hard clear tubing
3. Neat cable management
4. New Front Design
5. And couple surprises! ;)
Previous mods :
Project Prodigious - OCN's March 2013 MOTM
Other components will be added as I go through with the project. Comments, questions, critiques, and ideas are all welcome! Btw, not all the hardware to be used is final.
Sponsors:
Cooler Master
AquaComputer
rzN2xh8.jpg?1
Link to comment
  • Replies 25
  • Created
  • Last Reply
UPPPPPPPPPDDDDDDDDDDDDDAAAAAAAATTTTTTTTTESSSSSSSSSSS!!
I just finished the new motherboard tray for this project, I'm calling it MoboTray V2.0. The Idea behind this mod is to have a space between the two mobo plates where I can route all the cables and keep the back of the case
as clean as possible. The result, for me, was outstanding. For mounting it on the case, I used the stock holes of the case and attached it using couple thumbscrews. With it, I can easily install or take it out of the case. :)
This is just one of the unique/innovative mods I will do for this project so please keep checking the build log! :)
Link to comment
  • Create New...
Important Information
