tantric Posted July 24, 2014 Author Share Posted July 24, 2014 Corsair H80 Fillport Mod -made the custom fillport out of spare 4.5mm acrylic. -tap threaded and glued onto the rad. -done Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -planning out the rigid tubing, and custom water channel. -i'm using 2mm acrylic sheet as a marking template to line-up the holes on the water channel. -checking for final measurements before i disassemble the case and again and prep it for powder coating Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 blacked out WD Velociraptor using plastidip. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 custom wiring my radiator fans Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 what to do with a spare HAF 932 front grille? Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 custom hdd mount for the velociraptor. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 i was finally able to get the acrylic pieces from the lasercutter. assembling the pieces together. forgot to order pass-thru fittings so i made one using 2 pieces of round acrylic glued together and threaded to G1/4" the completed custom water channel. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 test fitting to check if it lines up with the pump and radiator. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 my custom water channel also doubles as a cable guide for the psu wire cables. Link to comment Share on other sites More sharing options...
