tantric Posted July 24, 2014 Author Share Posted July 24, 2014 more updates on the paintjob. i left the panels overnight while waiting for the paint to properly cure. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 this deepcool fan hub is pretty useful, when you need to wire up the fans for your radiators without having messy wiring running all over the place. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -i also started working on the rigid acrylic tubing i'll be using to link the pump and water channel. i started by taping the rigid tubing so it won't get scratched in the process. filing out the edges. bending the rigid tubing using nitrile rod and heatgun. done! Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 my apologies for the lack of updates. my image hosting got bandwith exceeded and i had to re-upload and repost my entire album, that's around 200+ worth of pics. and with the deadline fast approaching i still need to finish a few more details on the case. (paint, sleeving etc...) -reservoir installed, i decided to make all the components in the watercooling compartment all black. tubes fitting reservoir and fittings. -filling her up... -a quick preview Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -doing the layout on the custom mobo tray cover. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -modding the side panels Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -a few pics of the acrylic accent pieces that' i'll be using on the case. sorry for posting random pictures. -side panel cover -PSU shroud -top panel cover -the custom front panel Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 -sleeving done. thanks to our friends from FTW Industries for the high quality cable sleeves. the colors also blend perfectly! -installed in the case. Link to comment Share on other sites More sharing options...
tantric Posted July 24, 2014 Author Share Posted July 24, 2014 more random shots... psu shroud details on the side panel. top panel corsair H80 custom cover front panel Link to comment Share on other sites More sharing options...
