MegaSkot Posted January 27, 2015 Share Posted January 27, 2015 It's time for a new preoccupation. Here are some basic ideas: MB: Asrock Fatal1ty X99M Killer - sponsor AsrockCPU: Intel i7 5820KVGA: Inno3D GTX 970 OC SLIRAM: AVEXIR AVD4U24001604G-4CIR Core Series 16GB Kit (4GB x 4) - sponsor AvexirSSD: Transcend 2x256Gb - sponsor TranscendPSU: Cooler Master V1000Fans: Eight pieces Raijintek Aeolus α - sponsor RaijintekAll water cooling sponsored by: EK Water Blocks 1. home made huge external radiator - wall panel type2. custom built case made of stainless steel and plexiglass in shape of Superman logo3. plexiglass water block, yellow and red liquid will go through the "S" logo I started with a radiator: heat exchangers, 4 pieces of 500x420x25mm. Link to comment Share on other sites More sharing options...
MegaSkot Posted January 27, 2015 Author Share Posted January 27, 2015 Brass pipes for connecting radiator pipes: Link to comment Share on other sites More sharing options...
MegaSkot Posted January 27, 2015 Author Share Posted January 27, 2015 I'll make brass fittings by myself. Those ones on pictures will be connected to the brass pipes. Two inputs, two outputs and two fittings for inserting liquids in the system. Standard thread: G 1/4. Switches with LEDs have been ordered engraved. Link to comment Share on other sites More sharing options...
-=SpH!Nx=- Posted January 27, 2015 Share Posted January 27, 2015 Love the engraved switches! Link to comment Share on other sites More sharing options...
MegaSkot Posted January 27, 2015 Author Share Posted January 27, 2015 Thanks. Working on radiator: Link to comment Share on other sites More sharing options...
MegaSkot Posted January 28, 2015 Author Share Posted January 28, 2015 Some basic ideas for case... Link to comment Share on other sites More sharing options...
MegaSkot Posted February 4, 2015 Author Share Posted February 4, 2015 Final render: Link to comment Share on other sites More sharing options...
MegaSkot Posted February 22, 2015 Author Share Posted February 22, 2015 Frame for radiator: aluminum square tube 20x20x2mm.Frame dimensions are 115x75x15cm, aluminium is connected by welding.Position of the radiator is up to the right , to make room for two D5 pumps and reservoirs. Thanks to Transcend, first SSD here: Transcend 370, 256Gb. Link to comment Share on other sites More sharing options...
MegaSkot Posted February 22, 2015 Author Share Posted February 22, 2015 BIG THANKS to EK Water Blocks for sponsorship 1. EK-Supremacy EVO – Nickel2. EK-FC970 GTX - Nickel – 2 pieces3. EK-HDC Fitting 16mm G1/4 - Blue – 45 pieces4. EK-FC970 GTX Backplate - Nickel – 2 pieces5. EK-MOSFET MSI X99 MPower - Nickel - 2 pieces6. EK-XTOP D5 PWM - Plexi (incl. pump) - 2 pieces7. EK-Ekoolant Pastel YELLOW (concentrate 250mL) – 3 pieces8. EK-Ekoolant Pastel RED (concentrate 250mL) – 3 pieces9. EK-SB ASUS M6G - Acetal+Nickel Link to comment Share on other sites More sharing options...
MegaSkot Posted February 25, 2015 Author Share Posted February 25, 2015 Stainless steel 1mm case panels, after laser cutting. Link to comment Share on other sites More sharing options...
