Jump to content
Project phoenix
p01arst0rm
Ok guys.. here we go...
I am Going to be modifying the Toshiba satellite pro a300 laptop. yes thats right. a laptop. you may indeed call me crazy, maybe so ambitious, but by :) or high water i am doing this!!
The plan:
sooo modding a laptop i much more complex than a tower mod (no offence to the custo tower builders, y'all lovely people). you have to rip apart components like the batteries, create custom mounting hardware; it gets complex :D
i think its a good idea to lay out a plan:
create the back of the monitor housing
paint said housing
install the wifi antennas in the housing with the screen
create front plate and hinge covers
create the base of the laptop
paint said mainboard
create mount points for the mainboard and screen hinges
upgrade the mainboard with a new processor and (maybe) new ram
install the mainboard in the base
install new drives into the laptop
create a top plate with mounting points for power lights, trackpad, power button and keyboard
install the battery after testing the grounds of the mainboard
install the top plate
install a tri boot os setup :P
i think this is a good outline... wish me luck :D
link to laptop spec page --> http://www.toshiba.co.uk/discontinued-products/satellite-pro-a300-193/
Link to comment
  • 3 weeks later...
  • Create New...
Important Information
