Joshua Kim Posted February 7, 2015 Share Posted February 7, 2015 Project Fraxinus -inspired from the anime Date A Live, The Airship Fraxinus -The Mission The concept of this RIG is to Build/Mod PC Cases without spending too much on parts. The name “Fraxinus†came from the anime Date A Live, the Airship Fraxinus With parts available at my home, i aim to build a Compact and a Quality PC Case without spending too much on the parts. Aside from building a Compact and a Quality PC Case, i aim to promote PC Case Modding and share the passion of Case modding Here on General Santos City as most of the people here who owns a computer does not know what can they do with their cases, And whenever there is an RIG Events here, the participants are mostly from other Cities with their custom cases. And most people say that Case modding cost much, yes it does, but let's think out of the box here, aside from buying premium things (cases, pipes and stuff) why don't we try using things from our garage? Or even things in the junkshop? The Goal is to Build A Compact And A Quality case without spending too much with that in mind, the water cooling parts that i'll use on my project might surprise you. --------------------------------------------------------------------------------------------------------------------------------------------------- To Expect at the end of the project Watercooling with things from garage Frankenstein PC Poor Man's Rig Custom Water Reservoir Custom Waterblock (TBC) A/C Condenser as the Water Radiator Video Worklog maybe? Hardware Specs Processor: TBA Motherboard : TBA RAM:TBA PSU: TBA Casing : Generic Casing (got a backup casing just in case) Water Pump : Fuel Pump from Mitsubishi Pajero The Plan Drill Hole for a Power Switch (RS Part number 436-913) Custom Back I/O Custom Cut Case For an A/C Condenser ( Yes A/C condenser as a radiator!) Custom Cut Fan Grills Custom Case Feets Custom Front Panel And Cutting for Front Fan Grills Repaint Whole Case Probably Plasti-Dip Motherboard Repaint the whole Case TBA Link to comment Share on other sites More sharing options...
Joshua Kim Posted February 7, 2015 Author Share Posted February 7, 2015 [02-07-15] Front of the Case Pump for Watercooling Hole for the Custom Switch [EDIT: Resize Image] Link to comment Share on other sites More sharing options...
Joshua Kim Posted February 8, 2015 Author Share Posted February 8, 2015 Parts Arrived! [ 02-08-15 ] FAN and Pump Controller (Gonna make custom circuit for pump) The switch (RS 436-939) Link to comment Share on other sites More sharing options...
Joshua Kim Posted February 12, 2015 Author Share Posted February 12, 2015 UPDATE 02-12-15 More Parts! Dremel!! More wires (for fans and switch) The Rad- Condenser-Radiator! Copper Pipes Link to comment Share on other sites More sharing options...
Joshua Kim Posted March 9, 2015 Author Share Posted March 9, 2015 UPDATE [03-09-15 PH] Almost a month since the last update lol. have been busy for awhile Semi-Custom LED Lights for fan controller, Blue -> Red BEFORE NEKKID AFTER Link to comment Share on other sites More sharing options...
-=SpH!Nx=- Posted March 9, 2015 Share Posted March 9, 2015 Hey! Good stuff there! But I have a question, are you "Modding" an existing case? Link to comment Share on other sites More sharing options...
Joshua Kim Posted March 10, 2015 Author Share Posted March 10, 2015 Hey! Good stuff there! But I have a question, are you "Modding" an existing case? Thanks! and Yes, actually it is an Generic case, although right now i am planning to make a case from "scratch". Link to comment Share on other sites More sharing options...
Joshua Kim Posted April 3, 2015 Author Share Posted April 3, 2015 DRILLING HOLES FOR Custom I/O Link to comment Share on other sites More sharing options...
