Julian Nordseth Posted May 15, 2015 Share Posted May 15, 2015 Hi there im Hype! Building computers have been a hobby of mine for the past 10 years and ive spendt hours looking at people building Desk's until i finaly decided to make an attempt to build one of my own. FEEDBACK OR SUGGESTIONS APPRECIATED! Making this Worklog to keep track of my progress. Decided to do so a little late, thats why i dont have any pictures of the case pre assembly. Either way ill link what i have for both my own sake and everyone who is, like me, interessted in these types of builds. This is the first picture ive taken. Made all the bottom parts of the desk. Next step is straightning out the Lines to make everything even for the top frame with the glass and finishing the Holes for the fans and parts. Smoothen everything out by hand using sandpaper (yes, my supply of fancy tools is limited) Making the holes next! Decided to make the fan Holes Square instead of circled beacuse it will look way better with the grills ive ordered From Phobya. Stilling need to make some holes + Ventilation for the PSU. Decided to keep the compartments between the MB and other parts separate from the Radiators for better AirFlow. Got most of the parts im going to use in the Computer im currently using, including my 2 Tripple extra thick Rads From EK-WB. Will add a picture of the parts as im picking it apart. Checked how the components fits with some old spare parts, its will look something like this before the fun Stuff begins. Decided to build in the PSU and add a Double Bottom to hide the cables. Will get the materials + Carbon Fiber to cover the top floor tomorrow and hopefully my Grill's have arrived. Will add updates as i make changes. Probably 4 times a week since i cant stop working with it. Having the time of my life! Link to comment Share on other sites More sharing options...
-=SpH!Nx=- Posted May 15, 2015 Share Posted May 15, 2015 Found yah! Subbed! Link to comment Share on other sites More sharing options...
Julian Nordseth Posted May 15, 2015 Author Share Posted May 15, 2015 Added Frames to the top of the desk to better support the Tinted Glass top. Soon ready for paint. Also working on the Double Bottom(pictures later). Still waiting for my damn grills ^^ Link to comment Share on other sites More sharing options...
Julian Nordseth Posted May 23, 2015 Author Share Posted May 23, 2015 Going to finish sanding it down and paint it tomorrow! Also started to order some parts for it! Ordered so far: Phobya Rad Grills + connectors and cables for the fans and Power Buttons. 2x MSI GTX 970 Twin Frozr with EK-WB Waterblock's Asus Maximus V formula (the one with the heatpipes for water cooling) Intel i7 4790K Processor. Arctic 2 Paste Some parts for the loop. Including tubes. what you think ? Its not meant to be the sickest gaming rig but still able to run most of the games out atm. Pictures will come later! Link to comment Share on other sites More sharing options...
Julian Nordseth Posted June 1, 2015 Author Share Posted June 1, 2015 Just bought a apartment so had to cancel my Order with the parts for now. But i have finished the rest of the case and got some parts from Phobya. Getting some help with the sanding and paint since i have never done it before. Here is some pictures. Made holes for the Power/reset button and the fan controller. Made holes for the water cooling and the fan cables as well. Still having a second floor to hide the wires. Phobya fan grills, power buttons and Connectors. Going to look much smoother after sanding it down and caulkt it. Getting it done this week Link to comment Share on other sites More sharing options...
Pclinde Posted June 9, 2015 Share Posted June 9, 2015 Making some good progress! Good luck dude. Link to comment Share on other sites More sharing options...
Megadeblow Posted June 10, 2015 Share Posted June 10, 2015 better than my 1st attempt looking good, hope everything goes to plan for the rest of the build Link to comment Share on other sites More sharing options...
Julian Nordseth Posted June 10, 2015 Author Share Posted June 10, 2015 Thanks guys! Slow and steady wins the race Almost done with all the work before the paint, only the inside left and some sanding outside. The ground paint was done outside and it was to cold so got a few bubbles. Going to make it black but plan on making Frames under the fan Grill's to make it more special. Added some pictures. Also ordered Acrylic tubes and nipples for the watercooling. Link to comment Share on other sites More sharing options...
Julian Nordseth Posted June 29, 2015 Author Share Posted June 29, 2015 Someone able to help me out ?! People have replyed that they cant see the pictures on my post ? i cant see them myself unless im logged in on my account. Why is that ? Link to comment Share on other sites More sharing options...
