KrypteK PC Modz Posted May 27, 2016 Author Share Posted May 27, 2016 Hey guys I'm back!! I got some little update for my front panel and fans.. I put a fan guard and the I made a custom Astray logo. Hope you'll like it. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 27, 2016 Author Share Posted May 27, 2016 Painted with primer spray can.. Ok guys, that's all for today. Stay tuned! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 28, 2016 Author Share Posted May 28, 2016 Little update! Almost done with the outer part of the build.. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 30, 2016 Author Share Posted May 30, 2016 Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted May 30, 2016 Author Share Posted May 30, 2016 Thanks to OCZ for letting me use their SSD Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted June 2, 2016 Author Share Posted June 2, 2016 Hey guys! Have some a little update for my case mod.. I made a front panel power switch Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted June 2, 2016 Author Share Posted June 2, 2016 So as of now, while I'm waiting for the Bitspower items that I'll be using for the water cooling loop I just made the side covers of the chassis. View of the front panel.. Later I will move the radiator/fan holder forward.. Ok guys, stay tuned! Thanks for viewing! MOD ON! Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted June 2, 2016 Author Share Posted June 2, 2016 Hey guys! Good evening Update with the front and power button... So tomorrow i'll be cutting the radiator/fan holder to move forward the fans and radiator.. Stay tuned. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted June 3, 2016 Author Share Posted June 3, 2016 Hey guys! I'm done cutting the front radiator/fan holder I put aluminum angle bar to make a new radiator/fan holder.. Link to comment Share on other sites More sharing options...
KrypteK PC Modz Posted June 4, 2016 Author Share Posted June 4, 2016 Moved and I made a radiator/fan holder. Fan testing.... Link to comment Share on other sites More sharing options...
