Gamerznation Posted March 4, 2017 Share Posted March 4, 2017 KAAL_GATI- Speed Of Time HI, I am Vinay Agrwal from India. I have a venture named Gamerz Nation where i build and mod PCs for clients. you can follow my work on my page or my facebook profile . Gamerz Nation facebook page - https://www.facebook.com/Gamerznationpune/ Vinay Agrawal Profile - https://www.facebook.com/vinay.agrawal.23/ This mod is based on Time Machine concept performed on Cooler Master MasterCase 5 KAAL- Time GATI - Speed In this mod i wanted to create a Computer which looks like a time machine from the future. So i started with the black ,white an clear theme. i also wanted to give it a different open mechanism where the user can see the whole motherboard and Gpu one he open the front panel.(Yes the Front panel ) lets do this !! Starting with the Case i opened the case from all the sides including the back I/O port panel as it has to customised for a slant placement of the MB. Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 List of components used in the build: Sponsored: Cooler Master Mastercase 5 intel i7-7700k Gigabyte AORUS Z270x-Gaming 5 Hyper x 2400Mhz 16Gb (2 X 8Gb module ) Hyper x 240gb Fury SSD Tweaked PC Custom Sleeved cables Pre-owned: Cooler Master B600 600w power supply Cooler Master Masterliquid lite 120 Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Marking The cut After a little filling this is ow it looks back panel cut Little support at the back and front and the structure is standing Now measurements for the MB tray: MB tray is fixed with pop-rivets and screws Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Now the Front structure opening mechanism Fixed with door hinges and Pop-rivets It is perfectly opening and closing Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Now covering the PSU shroud with Acrylic sheets Measurements and execution First Demo with cardboard sheets checking for gaps Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 For the Outer covers added acrylic panel shields Measurements and cutting Panels are then folded for 130 degree angle to match with mastercase 5 outer surface Testfit Random tech design on the panels to give futuristic look Cutting the marked designs Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 after cutting and fitting if the front panel Wrapping with carbon Fiber vinyl completed Wrap fitting the front panel Painting the case black again for any paint removal during all the cuttings and fittings Painting the shroud black before wraping it after wrapping and cutting of the Shroud fiitings are done for test Finished fittings and painting of the case Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Top vent customization IO panel front cover Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Side panel which opens with the front Now as the structure is ready we will start with the detailing Link to comment Share on other sites More sharing options...
Gamerznation Posted April 30, 2017 Author Share Posted April 30, 2017 Details and Small fittings for the future looks PCB lines on front and top panel after long and slow cutting we have one pcb line ready :[ repeating the process for times we get same process for the side panel Kaal_Gati is nearly complete Link to comment Share on other sites More sharing options...
