Sa mod Posted September 17, 2019 Share Posted September 17, 2019 (edited) Hello everybody, I will show you my project. It's a tribute to Ferrari and I will use leather to cover it. Specs: Coolermaster Cosmos c700p Asus strix x470 Ram Dragonheart S3+ 4x8 2666 mhz ssd m2 512 gb S3+ Alphacool watercooling Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 17, 2019 Author Share Posted September 17, 2019 (edited) Massive thanks to Coolermaster Italia, Asus Rog Italia, Alphacool, Touchthegame, Gszcustom, S3 Plus Technologies, Italian extreme modders. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 17, 2019 Author Share Posted September 17, 2019 (edited) Let's start to work. I started to disassemble cosmos c700p. After I painted chassis. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 17, 2019 Author Share Posted September 17, 2019 (edited) Now I started to work on the front panel. First I created paper template. After I prepared another paper template for stitchings. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 17, 2019 Author Share Posted September 17, 2019 (edited) Now I glued leather on the front panel and I trimmed the edges. I did also a test for the badge. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 17, 2019 Author Share Posted September 17, 2019 (edited) Now I created top panel's paper template. I cut the leather. I glued the leather on the top panel and I trimmed the edges. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
GS Customz Posted September 19, 2019 Share Posted September 19, 2019 Looking great buddy! Can't wait to see the custom loops and custom cables in actions 1 Link to comment Share on other sites More sharing options...
MAYHEM MODZ Posted September 20, 2019 Share Posted September 20, 2019 On 9/17/2019 at 11:36 AM, Sa mod said: Now I started to create the paper template of the top panel. I cut the leather. I glued the leather on the top panel and I trimmed the edges. this is a perfect ITALIAN job!! Link to comment Share on other sites More sharing options...
Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 (edited) Now I started to work on front panel's internal part and I created paper template. I cut the leather and I did the stitchings. I glued the leather and I trimmed the edges. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 (edited) Now I started to work on the back panel and first, as usually, I created paper template. I cut the leather and I did the stitchings. I glued the leather and I trimmed the edges. Edited October 1, 2019 by Sa mod Link to comment Share on other sites More sharing options...
