Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 I started to work on the side panel and first I created paper template. Now I cut the leather and I did the stitchings. I glued the leather and I trimmed the edges. Link to comment Share on other sites More sharing options...
Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 Now I created cover psu in plexiglass. After I created paper template and I added a thick. I cut the leather, I did the stitchings and I glued the leather. I added particular details of leather. I attached a laser plexiglass writing. Link to comment Share on other sites More sharing options...
Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 Now I started to work on the internal panel. I assembled motherboard Asus x470 strix, cpu and gpu waterblock Alphacool, ssd S3+ and ram S3+. Link to comment Share on other sites More sharing options...
Sa mod Posted September 30, 2019 Author Share Posted September 30, 2019 Now I created paper template and I cut plexiglass. I did holes for cables and I started to bend tubes, I took measurements to do holes for passthroug and I did them. I finished to prepare tubes of the front part and I fixed reservoir. At this point, I did also the back tubes. Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 Now I disassembled and I started to apply the leather on the panel. I glued the leather and I trimmed the edges. I did details for holes. This is the finished work of pc interior design. I created also a little panel to cover cables . Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 Now I assembled all again. Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 I added plexiglass details. Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 Now I did cables management. I filled loop. Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 These are finally photos ......stay tuned for final video. Link to comment Share on other sites More sharing options...
Sa mod Posted October 1, 2019 Author Share Posted October 1, 2019 Link to comment Share on other sites More sharing options...
