mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 processing and conclusion of the lower panel... lower casing that will contain the controller of fans and rgb lights of the whole case. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 13, 2021 Author Share Posted January 13, 2021 positioning of lights on the support of the internal panel. positioning of lights on the support of the internal panel. completion of the internal panel and graphics And it's not over yet... https://forums.bit-tech.net/styles/default/xenforo/clear.png Link to comment Share on other sites More sharing options...
mayhem modz Posted January 18, 2021 Author Share Posted January 18, 2021 custom Ek watertblock coolermaster riser arrived mounting gpu block EK Link to comment Share on other sites More sharing options...
mayhem modz Posted January 18, 2021 Author Share Posted January 18, 2021 installing 5 inc display front panel buttons- internal cover update yaiba logo paint back cover ssd internal panel psu cable contenitor panic.... I realized that the radiator is too long about 4 mm and the lower panel closes, duqnue I create a hole to gain space and cover it with a themed element .. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 20, 2021 Author Share Posted January 20, 2021 working on ssd covers Link to comment Share on other sites More sharing options...
mayhem modz Posted January 20, 2021 Author Share Posted January 20, 2021 installing cables.. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 20, 2021 Author Share Posted January 20, 2021 custom loop ek waterblocks tuff! Link to comment Share on other sites More sharing options...
mayhem modz Posted January 20, 2021 Author Share Posted January 20, 2021 ..a bad news... problems on external panels the red paint not support other kind on paint over the solution is vinil.. , I'll re do them.. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 21, 2021 Author Share Posted January 21, 2021 charging liquid and colour.. Link to comment Share on other sites More sharing options...
mayhem modz Posted January 23, 2021 Author Share Posted January 23, 2021 reassembling yaiba cable management and rgb fan cobntroller inside psu cover Link to comment Share on other sites More sharing options...
