Patrick Fan Posted December 11, 2020 Author Share Posted December 11, 2020 Tried to sand in a brushed finish Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 12, 2020 Author Share Posted December 12, 2020 Little bit of wet sanding up to 4000 grit has made this plate clear as day. Thanks bittech for recommending mirka abralon the soft pads are amazing. Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 12, 2020 Author Share Posted December 12, 2020 Had to drill a new hole for the power button so it didn’t collide with a fitting. Whole case was vibrating like crazy. Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 13, 2020 Author Share Posted December 13, 2020 Rewired ddc to 6 pin Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 15, 2020 Author Share Posted December 15, 2020 Added drgb controller Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 15, 2020 Author Share Posted December 15, 2020 My first bend and air bubble Link to comment Share on other sites More sharing options...
Patrick Fan Posted December 16, 2020 Author Share Posted December 16, 2020 I got rejected from Columbia today but I did get my computer to boot. All that’s left to do is tubing and leak testing. You win some you lose some lmao. Link to comment Share on other sites More sharing options...
