Jump to content
CincaiLah - Myvi, King of The Road
Paji
 Share
Day 15
For the bonet and boot, I used disposable chopsticks and super glue to make the hinge mechanism.
After that, I used a brush to paint the undercoat and let them dry for 24 hours.
Link to comment
Day 16
I used a drill and a router table to make a slot that holds the PSU power cable extension plug
Then, I sand off the  uneven surfaces of the undercoat paint up to 500 grid to get a smooth surface for the black paint later.
For the black paint, I bought an F-75 air spray gun to paint it. I coated it 4 times to get a really glossy surface and a thicker protection to the case. I also painted the L-brackets. Then, I let them dry for 50 hours.
Link to comment
Day 17
For the wheels, I've bought two pairs of 90mm diameter RC Car wheel, they looked really awesome but rubber tyre part is way too soft, it flattens whenever it's loaded which doesn't look great.
To solve this, I've tried stuffing papers, cloths or even tiny wooden pieces in the tyre but they all didn't really worked out for me. At the end, the perfect solution for this is to cut some hard sponges into the shapes as shown in the picture with the width of the inner part of the tyre and stuffed them in evenly.
To secure the wheels onto the case, I used the same M4 threaded inserts as the connector for the wheels that came along was also M4 in size.
Link to comment
Day 18
After all the paints are completely dry, I decides to make a test fit for one last time before the actual assembly and also roughly worked on the cable management
Also note that the AIO CPU Block was sticking out as I'm only gonna replace the cooler and the thermal paste on the final assembly.
**Note: I borrowed ARGB Ram sticks from my friend to make it look better, they are not the ram sticks I mentioned in the specs.
Edited by Paji
Link to comment
Day 20 - FINAL ASSEMBLY
Disassembling my current PC, and today my friend came over to help the final assembly
Cleaning off the old thermal paste on the CPU with alcohol swab and cotton bud
Unboxing new components
All of the computer parts I'll be using for this PC Case
Assembling the basic shape of the case
Placing the PSU and connect it to the the custom Modular Cables
Screwing the brackets that holds the bottom case fan
Placing the GPU and connect it to the PSU
Place the CPU and applying new thermal paste
Placing the AIO CPU Block and lock them in place
Placing the Motherboard and connected the PSU Cables
Managing the cables, connecting the fan hub, the ARGB Cables, and arranged them using cable ties
Screwing the wheels in
Plug and Play!
It is working!
Edited by Paji
correction
Link to comment
FINAL SHOTS
Special Features:
Thank you, to the people who helped me through this entire journey, and you for reading.
It's been fun!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
 Share
  • Create New...
Important Information
