Jump to content
Nemesis V2.0 Cooler Master 2011 Case Mod Competition
mcj66106
Case mods will include inverted MB, side panel window, redesigned front panel and new top panel all fabricated from 6061 T6 aluminum. More mods to be announced at a later date.
Hardware list.
MB ASUS Rampage III Extreme
CPU i7 920
PSU Corsair HX1000
Video card Evga GTX580
Sound Blaster X-Fi Titanium Fatal1ty
Ram Corsair Dominator GT 2000 6Gb
HDD 1Tb Barracuda
SSD Corsair X128
Tygon R3400 1/2in. ID 3/4in. OD
HK 3.0 RRT chrome plated
aquagraFX GTX 580
2x Thermochill TA120.3
12x Bitspower True Brass 1/2in. Compression Fittings for 3/4in. OD
3x Bitspower G1/4 True Brass Male to Male
2x Bitspower Matt Black Rotary 45
EK-Multioption RES X2 - 150 Advanced
1x D5 pump
1x Bitspower D5 MOD TOP V2 (Acrylic Version) With UV-Reactive Blue O-ring
1x Silver KillCoils by iandh
Link to comment
  • 2 weeks later...
Im just getting the hardware together at this point. There will be many more mods to the case as well as the hardware. To start the mother board will be inverted. The next step will be to construct a new front panel and top. Then it will be time for the more creative stuff.
Right now every thing is on hold. The new ram should be delivered around 3p.m. today. So I should be working on the new front panel and top tonight and the next few days.
Link to comment
  • 1 month later...
Small Update.
This is how it sits right now. Added drain line and corsair X128 SSD
Tonight I will be ordering a new 250 Advanced res because the one I have now just doesn't look right. Also on that order will be a bunch of BP brass couplers to replace the tygon tubing going from the res to the acrylic T block. I will also be adding a fill line from the fill port on the top of the case to the new res.
There is still a lot to do but I think it has come a long way.
It still needs the front panel made and all of it still needs a good cleaning and powder coating.
Link to comment
  • Create New...
Important Information
