Jump to content
Scratch Build : Desk Art - FINISHED -
Paslis
Hi all ,
My name is Pascal and im from the Netherlands and im a welder/metalworker for 22 years now.
Many woman dont like a pc in the livingroom so i was thinking about a good solution to make a desktop that looks like it belongs in a livingroom.I came up with the idea to make a desk.After using the version 1 there were some things to improve so i decided to make a second version of my desk.This is the first time that i made a build log.
Here some pictures of version 1 it was finisht 18-06-2010
So here is my build log for the second version.Im making my whole scratch build at my work using all the machines there.
The drawings atleast a few of them.The rest i made with the software of the lasercutter.
And a custom reservoir.
Hardware :
PSU: Cooler Master 800W Silent Pro Gold
CPU: AMD Phenom II X6 1055T
GPU: XFX HD6970 2GB GDDR5 PCIE
Mobo: Asus Crosshair IV Formula
Mem: 8GB Corsair Dominator GT 1866c9
Sound: Creative X-Fi Xtremegamer
SSD: Crucial RealSSD C300 2.5" 64GB
HDD: Western Digital Caviar Green WD10EADS 1TB
Loop :
Pump : Swiftech MCP655
Rad 1: XSPC RS240
Rad 2 : XSPC RS120
CPU block : EK-Supreme HF Nickel CPU Block
GPU block : EK-FC-6970-Nickel
Tube: Feser Tube UV - HighFlow - 1/2 ID - 3/4 OD - RED
Fittings : Bitspower (1/2 ID - 3/4 OD)
Res: custum made by me
I began this project 19/12/2010.
Frame for the desk made out of stainless steel.
Cutting the desk
I made a movie of the lasercutter while cutting my backpanel.
Welding the desk.
Making the custom reservoir.
I made a movie while leak testing.
Mobo tray,reservoir tray and fancovers.
Rad covers.
The gas springs and the frame for the window.
Drilling holes in the glass window.
Back panel with Desk Art bookmarks.
Custom made reservoir on the reservoir tray with uv lights.
This is how the desk looks now.
More to come.
Link to comment
  • Replies 26
  • Created
  • Last Reply
Today i finisht the window section.
The edge cut from 3mm stainless steel for the attachment of the glass.
The glass is 6mm thick so I cut strips of 6mm thick and put the edge on it.
I then welded the edge with welds of about 5mm and then it was time for coffee.
Everything ready to fit.
Everything fits perfect so this section is finisht.
More to come.
Link to comment
Excellent work man, but tell me; how did you calculate what size of those pneumatic cilinders to hold up the lid ?
Love that lasercutter :)
Thanks FrenkieNL.Well the window and the lid weigh 10kg so i bought gas springs that can handle 10kg and it works like a charm.
Link to comment
  • Create New...
Important Information
