kyosukemodX Posted March 3, 2011 Share Posted March 3, 2011 Withdrawn.. Thanks Coolermaster Link to comment Share on other sites More sharing options...
kyosukemodX Posted March 4, 2011 Author Share Posted March 4, 2011 more progress soon Link to comment Share on other sites More sharing options...
PaPang Posted March 4, 2011 Share Posted March 4, 2011 Hola Bryan! Great to see someone from the Philippines! Great modding community and home of the some of the most creative minds in the hobby. I wish you the best of luck and hoping to see a great mod in the making. I couldn't expect less, hehe. I expect to see bro' sunnyxtremist to drop by and cheer you one too! Cheers and Saludos Link to comment Share on other sites More sharing options...
kyosukemodX Posted March 5, 2011 Author Share Posted March 5, 2011 thanks papang, progress is still ongoing just brainstorming for the designs revision.. Link to comment Share on other sites More sharing options...
FrenkieNL Posted March 5, 2011 Share Posted March 5, 2011 Nice to see you here, i want to wish you good luck and lots of great ideas ! Link to comment Share on other sites More sharing options...
kyosukemodX Posted March 12, 2011 Author Share Posted March 12, 2011 to continue my worklog i use aluminum angle bar to support my door hinges measuring and drill a hole for some screw to fit in drilling.. Ill post what it looks like later because its getting dark lol Link to comment Share on other sites More sharing options...
kyosukemodX Posted March 13, 2011 Author Share Posted March 13, 2011 here it is and as you can see some of the paints strips off but it can be fix easily next i painted the odd bay plus the hdd rack and twist the hdd rack to hide its cable and also the mesh that comes from the side panel, i cut it and place it to the odd bay if ever i want to add a fan and also for cable cabinet as well ( double purpose ) i made some concealer for the odd bay and hdd rack made out of clear acrylic ( by the way i found the acrylic in the trash and make it useful in my project ) this is where the acrylic fits in test fitting the hinges not final yet video card casing to make it looks like a very long card ( but it doesn't LOL ) Link to comment Share on other sites More sharing options...
kyosukemodX Posted March 20, 2011 Author Share Posted March 20, 2011 the case was already painted but need to retouch the paint because of some scratches after wet sanding Link to comment Share on other sites More sharing options...
