mindphaser7 Posted April 27, 2011 Author Share Posted April 27, 2011 Set sanitary hose clamp’s fastening in the upper two points: Modified shields: Shields with fastenings: Approximate shields layout: Link to comment Share on other sites More sharing options...
mindphaser7 Posted April 30, 2011 Author Share Posted April 30, 2011 Blanks for the lower two clamp fasteners: Fix the clamp on the both sides: Let’s finish the rolling out mechanism for CD’s container. Now it looks like: Remove the container – turned in a one-armed monster: And a new perspective: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 1, 2011 Author Share Posted May 1, 2011 I’ve been describe CD’s box container earlier, but in assembled mode photographing possibilities limited. Now we can take a closer look on this part of construction: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 3, 2011 Author Share Posted May 3, 2011 Guide arm will made from ½ inch pipe for mixer tap and piece of solid aluminum wire 35mm2 cross section: Insert wire in a pipe (for rigidly) and bend on sketching: With a fine file made a notch for drilling: Centering for drilling by self-tapping screw: While drilling holes, I press down the guide arm by wooden bar: Take a look at rollers. As a blank a tension pulley block with guide rollers was chosen: But roller profile not confirm with pipe diameter: Have to turn the roller in drill driver: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 4, 2011 Author Share Posted May 4, 2011 Make the improvised clamps: Fix the clamps on the shields: Assembled as an examples in other hose clip: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 6, 2011 Author Share Posted May 6, 2011 Secure shields on places: Since the furniture hinges retained its open/close function, shields may be in three positions. First, fully open: Second, fully close: And third, intermediate position, relatively stable: Looks better in an intermediate position for me: It is true that shields in general are not very noticeable, you need to look closely. Too sad… : Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 8, 2011 Author Share Posted May 8, 2011 In addition with the main works decide to restore order in the wires At first to fix metal hose from the “control panel†Choose the details: Quick assembly: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 10, 2011 Author Share Posted May 10, 2011 Mount guide pipe on the CD’s container holder: Prepare components for roller bracket: Well, the rollers block itself: Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 14, 2011 Author Share Posted May 14, 2011 Roller bracket holder made from table lamp leg: Try on roller block Have to adjust by height – remove one nut: Assemble and install everything in place: Tomorrow will be general cleaning and a final photosession. Link to comment Share on other sites More sharing options...
mindphaser7 Posted May 15, 2011 Author Share Posted May 15, 2011 Well, mod finished, tomorrow it goes for gold You've already seen the whole process of mod creation (I hope), therefore, will no longer surprises - only the new photos of known elements: And after all, some full-size photos (caution, traffic!): http://s53.radikal.ru/i142/1105/48/f78a0beef088.jpg http://s014.radikal.ru/i327/1105/c3/880a3a0b3410.jpg http://s006.radikal.ru/i214/1105/03/00152db89947.jpg http://s59.radikal.ru/i164/1105/a6/0ff2dd50999a.jpg http://s015.radikal.ru/i333/1105/a9/075d95d148a8.jpg http://s41.radikal.ru/i091/1105/11/a70442900239.jpg http://s57.radikal.ru/i158/1105/76/498d8eb325a0.jpg http://s013.radikal.ru/i324/1105/a0/6867e59da3c8.jpg http://s44.radikal.ru/i103/1105/8e/b9ac666aaaad.jpg http://s45.radikal.ru/i109/1105/9a/2abb3e987c14.jpg http://s41.radikal.ru/i092/1105/31/eebef6306b0b.jpg http://s012.radikal.ru/i320/1105/4d/1f5b08ead712.jpg http://s55.radikal.ru/i148/1105/46/b45e84d7a4ef.jpg http://s61.radikal.ru/i174/1105/12/21b28aaf5eae.jpg http://s50.radikal.ru/i128/1105/1e/8c60d1703b65.jpg http://i065.radikal.ru/1105/d0/60bfd6f7b7eb.jpg See you next time! Link to comment Share on other sites More sharing options...
